Windows 7: audio mixer problem
28 Dec 2010   #11
LiquidSnak
W7 Professional x64
Glad you got it figured out
 audio mixer problem
Do I need a Digital Audio Interface besides my Alesis Mixer
I have been giving Voiceovers a go and have been told that I need both my Alesis Miser as well as an Digital Audio Interface. My Mixer has a built in preamp and plugs directly into my computer by the use of an USB cord. My Alesis Mixer also has two XLR ports for my Studio Condensor Mic. But I am...
Missing Sound Mixer In Audio Options
For some reason my Audio/Sound mixer option is gone. I have enabled 'See Disabled Devices' and it doesn't show up. I know I have the ability because I have used it many times in the past. And I can't seem to find a solution, any tips?
Sound/Mixer icon has red cross. No Audio Output Device is installed.
Windows 7 32-bit won't play sound. Device Manager\Sound, video and game controllers\High Definition Audio Device ok. Double click and window says: High Definition Audio Device Properties\General: Device status says This device is working properly. Speakers are plugged in and make a crackle...
Volume Mixer Audio Output Indicator Gone
You know when you are playing an audio file and you are able to see the current output volume of the song in the Windows7 Volume Mixer as a semi transparent bar behind the volume slider? For some reason, mine is gone. Also when I put headphones in my PC it is really loud and I have to keep my...
Audio Devices Not in Mixer; nor Audacity
Now using Windows 7, but since Vista I have not been able to record sound from the speaker / sound device, using Audacity. I recently found that when opening the "Volume Mixer" - right clicking speaker icon on taskbar - there are only 2 sliders present ; for "Device" > it's Speakers, and for...
Mute the audio mixer application programmatically
hello all, I try to mute/unmute the available application mixer individually (not the master sound). Does windows provided any API to get this thing done? Thanks for help...
