I have been giving Voiceovers a go and have been told that I need both my Alesis Miser as well as an Digital Audio Interface. My Mixer has a built in preamp and plugs directly into my computer by the use of an USB cord. My Alesis Mixer also has two XLR ports for my Studio Condensor Mic. But I am...
For some reason my Audio/Sound mixer option is gone. I have enabled 'See Disabled Devices' and it doesn't show up.
I know I have the ability because I have used it many times in the past. And I can't seem to find a solution, any tips?
You know when you are playing an audio file and you are able to see the current output volume of the song in the Windows7 Volume Mixer as a semi transparent bar behind the volume slider?
For some reason, mine is gone.
Also when I put headphones in my PC it is really loud and I have to keep my...
Now using Windows 7, but since Vista I have not been able to record sound from the speaker / sound device, using Audacity.
I recently found that when opening the "Volume Mixer" - right clicking speaker icon on taskbar - there are only 2 sliders present ; for "Device" > it's Speakers, and for...
hello all,
I try to mute/unmute the available application mixer individually (not the master sound). Does windows provided any API to get this thing done?
Thanks for help...
