Audio Stuttering
  1. Posts : 91
    Win7 Ultimate x64
    Audio Stuttering
    I'm using the headset Steelseries HV2, just today the audio started stuttering, and it's getting really annoying.
    I've followed the sticky thread, toupdate my drivers.. no luck.
    Any help would be great appreciated, thanks!
  2. Posts : 117
    Windows 7 profesional
    I don't know if this will work but try unplugging your headphones, give the headset port on your computer the old nitendo blow. Then, before you plug your headphones back in again, unistall the headphones driver. ( Go to start | go to the Control Panel | Go to the option hardware and devices | then click on the device mananger | find your headphone software or the device on the list | right clik it then uninstall | restart your computer | plug your headphones in again and see if that works. ( If there is no driver for your headphone then this may not work it's worth a shot!)
  3. Posts : 91
    Win7 Ultimate x64
    Alright, I'm starting to have serious issues now.
    The stuttering sound have become more of a stuttering CPU now.
    Out of nowhere, my CPU Usage have became 80% and it's lagging like hell.
    After I start up my computer, the computer is insanely laggy for like 5minutes, then it's atleast useable.
    I've tried what U told me to try, jhansen, didn't work.
    Please, help me.
  4. whs
    Have you checked in Task Manager which processes use the CPU - but make sure you click the button "Show processes for all users".
    It may also be helpful to have a look into the Reliability Monitor at: Control Panel\System and Security\Action Center\Reliability Monitor. Double click on the red markers to get the details.
  5. Posts : 91
    Win7 Ultimate x64
    Task Manager looks OK, nothing unusual there.
    Reliability Monitor - Since I just reformated my computer, to see if that worked.. which it didn't.. it's calculating something, so I'll have to wait a few hours and wait.
    Is there anything else I can do in meanwhile?
  6. whs
    What do you mean "nothing" in task manager. If the system is spinning at 80%, some processes must be heavily involved.
  7. Posts : 91
    Win7 Ultimate x64
    Tha'ts what I thought too
    CPU on Firefox, Steam, MSN or anything is 00, and the Memory varies from 10k-80k (which is normal).
    And yet the CPU Usage is insane, however now it's down to 2-5% .
    It keeps going up and down,
  8. whs
    See attached picture
    Attached Thumbnails Attached Thumbnails Audio Stuttering-2010-12-22_1749.png
  9. Posts : 117
    Did your computer just start running slow when you plugged your headphones in?
