static from front audio jack??????
sogone209
1:49 PM
Eugene, Oregon
i have a acer ax1700-u3700 desktop computer. the front audio jack makes a static audio noise when moving the mouse. but when im not moving it it doesnt make noise. its worse when i click the start button and look threw the stuff on the menu. all drivers are current. upgraded bios to lastest at least i think. help plz
Windows 7 Professional x64 (6.1.7600)Amd Athlon ii x2 255 3.1 ghz4Gig Dual Channel DDR3 PC2-1300Amd Radeon HD 6670 1GB DDR5 256bit
gameing build
asus m4a89td pro/usb3
Toshiba Lcd 40inch Tv
1920x1080 60htz
Hitachi HDS721010CLA ata 1TB 7200Rpm
Cooler Master GX 550W
Cooler Master Silencio 550
Two 120mm fans, with stock heatsink with 140mm fan on top
20MBps
sogone209,
My first thought is to have you make and unmake the connection into that front plug many times and even hit it with air or better yet to use a little contact enhancer on the pin and make and unmake the connection. What happens is if the connections are barely being made then noise and interference can make it's ugly and noisy presence known.
Windows 7 Ultimate 64
MSI P67A-GD80 b3
XFX Radeon 7870 2GB DDR5
Sound Blaster Z Series Card
1680 X 1050 p
(1) 1 tb WD Black
(2) 1 tb WD green/sata II
(2) 3 tb Seagate Barracuda
(1) 120 gb OCZ Vertex SS
(1) Drobo 5N w/5 Seagate 3tb
CoolerMaster Storm Styker
Basic 120mbps down
Chrome and IE 10
Netgear Nighthawk router
Asus USB 3 & sata 6 PCIe card
Drobo 5N advanced NAS
i have cleaned out the port with air and cleaner? it seems as if its a static issue? with other things on my computer? like when my hd thinks it creats a static sound to my audio. i wonder how to fix this. cause my read audio jack is crystal clear. but i have my 5.1 hooked to that so i dont wanna keep switchin it for my headphoens so i use the front
gameing build
1920x1080 60htz
20MBps
This sounds literally like an internal issue and one that you won't have a driver work around on. Have you opened the case and checked the front ports connection to the mobo, I would unmake and make that connection and also see if you can route the audio ports leads in a different manner to reduce stray electrical signals.
MSI P67A-GD80 b3
1680 X 1050 p
(1) 1 tb WD Black
Basic 120mbps down
Chrome and IE 10
i have tried this before but on to the front of the audio jacks have i disconnected. should i disconnect both sides and wipe them off?? but also turn the computer off???
gameing build
1920x1080 60htz
20MBps
Yes please turn the computer off then check both sides.
MSI P67A-GD80 b3
1680 X 1050 p
(1) 1 tb WD Black
Basic 120mbps down
Chrome and IE 10
