Another Realtek Problem
  1. Posts : 3
    Windows 7 7100
    I have an asus motherboard and just recently installed version 7100 of windows 7
    The audio was working with what ever drivers windows automatically installed
    The other day, i downloaded the 2.26 drivers from Realtek, and the audio has not worked since
    It shows it is installed, but will only output through the spdif jack
    And how do I get the little realtek control panel to work too
    Thanks guys
  2. Posts : 28,845
    Win 8 Release candidate 8400
    Thanks guys
    Did the spdif jack work before realtek? is the realtek driver 2.26 32 bit or 64 bit?
    Waiting for info. BTW thanks for filling out your "system soecs"
    Ken
  3. Posts : 3
    Windows 7 7100
    Its 32 bit
    And I never used the spdif......
    The motherboard is an Asus M3A76-CM
  4. Posts : 85
    Windows 7 32-bit; no 64 coz its a P4 478
    Go to Control Panel>Search for 'Sound'>Click on the 1st result>Click on Speakers>Press 'Use Default'> Now log off>then re-log in>now try something that requires audio...
  5. Posts : 3
    Windows 7 7100
    But that's the problem. It didn't show speakers, just the digital out thing
  6. Posts : 28,845
    Since you never used the spdif and it worked before the 2.26 driver why not go into device manager and remove 2.26 (there is a rollback feature)?
    Good luck
    Ken
  7. Posts : 85
    Then so to uninstall a program> Remove the Realtek driver>then restart>let windows install the driver automatically
