Windows 7: Perplexing Sound Problem
16 Jun 2009   #1
Connor
Windows 7 Build 7100
Greetings,
I've been scouring forums, trying different scenarios/settings, and spent many hours trying to figure this one out.
Here's the situation:
My speakers are plugged in (Logitech 5.1 Surround Sound), I have the latest drivers from Realtek (Version 6.1.7100.0), and my sound is not muted. I can't hear sounds from audio files that I play (through Windows Media Player, iTunes, YouTube, Pandora radio, other music streaming sites, etc.) but I can hear sound from video games (Team Fortress 2, Counter-Strike:Source, WoW).
I've tried everything I can think of and numerous things on these forums as well as others. Maybe it's something obvious, maybe it's something I would never think of. Anyway, any advice or help is greatly appreciated.
I have included some screenshots of various sound settings that I have just in case that will help.
***It is also important that you know I do not have a sound card and that I am using onboard sound. I have had both Windows XP and Vista running on this machine before and have had no problems.***
I will check this thread frequently and post back with updates.
Other than that, 7 is pretty cool.
Regards,
Connor
Perplexing Sound Problem-notpluggedin.jpg Perplexing Sound Problem-volumebasr.jpg
16 Jun 2009   #2
Connor
Here's how I kind of fixed it:
Open Control Panel and click hardware and sound.
Click sound and in the pop up window it brings up, and right click speakers and choose properties.
Go to the Enhancements tab and scroll down and put a check by Speaker Fill.
This is the only thing that I changed and I now have the center, back right, back left, and subwoofer working. If anyone finds a way to work off of that and get the front left and right (most important imo) working that would be great.
18 Jun 2009   #3
Wintings
Windows 7 Pro 64-bit
Have you also investigated the "Configure" button (bottom left) on the "Sound" window? It may be that you are not correctly configured for 5.1 Surround. Just a thought.....
Perplexing! VMWare, DNS not responding
I did end-task on VMware because it was resuming a Win7 x64 VM at 2MB/sec. Later, after booting it up, I cannot access the internet from the VM. The host's internet works fine. Using VMware Workstation 10.0.1. Get this: I went back to an older snapshot of the VM, I did system restore on the...
Network & Sharing
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Sound problem perrsists even after new sound card
As some of you might remember, a few weeks ago I had a problem with sound after I built a new PC and kept my old Win 7 installation using sysprep: http://www.sevenforums.com/sound-audio/280175-onboard-sound-issue-new-pc-build-2.html#post2308990. The problem was that the volume levels were off, and...
Perplexing problem--disappearing place to click
Hi all. This is a tough one to explain and if this is the wrong place to post, let me know. Here goes--I built a new Windows 7 computer last Saturday (January 5). Here's what happens. Lets say I am telling Windows 7 to empty the Recycle bin. I "empty the recycle bin" and nothing seems to...
General Discussion
Sound problem - need to 'scan for hardware changes' to get sound
Hi everybody I have a fairly strange problem with my Laptop. It came originally with Vista and a while ago I updated to Windows 7 32bit Home Premium. Since then I don't have any sound after booting the Laptop. By chance I found out that when I go into the device manager, right click on the sound...
Hardware & Devices
Windows Media Player Problem - Sound/skipping problem.
Oh look, another windows media player problem, lol. Well, it's something really weird, at first i thought it was just my computer being all slow or the file was messed up, No matter what movie or format i play it makes this weird screeching noise. It also lags pretty bad. I tried the scans, i did...
Music, Pictures & Video
