Quote: Originally Posted by
Mike Connor
You don't have the plugs for 5.1 sound. The only speaker output plug there is the green front speaker plug. That will only allow stereo sound.
What physical plugs do you have on your machine and what colour are they?
Regards....Mike Connor
3 - One pink one green one light blue.
Problem is that I cant use my old soundcard as it completely blocks off the air intake of my GPUs fan.
Only alternative if this doesnt work is to try and find a slightly smaller soundcard that will not completely block off the card fan (seriously, there is 1mm distance between GPU and Soundcard).
