4.1 Rear Speaker Sound Problem
Kusajishi
12:49 AM
USA
I use a 4.1 surround sound setup with onboard sound, and I can't seem to get sound from my rear speakers. I only get sound from the front. I didn't update any new sound drivers, and used the Microsoft and ATI ones.
When I do the sound test, it shows that the 4 speakers show some sound activity from the green status bar.
But no sound is coming from the rear speakers. I switched my speakers around to test if the speakers themselves are faulty (and they aren't). I went to the RealTek website and downloaded the latest driver. After installation it prompted me to restart. After restart, all my files in my desktop disappeared! My rear speakers are still not making any sounds after the new driver. I did a system restore to get my desktop files back.
I had nearly the exact same problem when I used Windows XP x86 (the difference being my desktop files weren't deleted when I installed the latest RealTek driver in Windows XP).
These speakers used to be connected to a Sound Blaster card from an old computer, and the surround sound worked on that.
Can anyone help me?
Windows 7 Home Premium x64AMD FX-6300 Vishera 6-Core 3.5 GHz (no overcl...G.Skill Ares 16 GB (2 x 8 GB) DDR3 1866Zotac ZT-70605-10M GeForce GTX 750 Ti, 2GB DDR5
Custom Built By Me (10/23/2015)
AMD FX-6300 Vishera 6-Core 3.5 GHz (no overclocking)
ASUS M5A97 R2.0
23" Hannspree HD LCD
SDD Silicon Power S60, 240 GB, SATA III
HDD Western Digital 1TB SATA
Rosewill ARC-M650, 650-Watt
DIYPC Ranger-R5-B ATX Mid Tower
Comcast Cable
Speakers: Logitech Z560 THX 4.1 Speaker System, Optical Drive: DVD-Burner
I have the same problem on my laptop, just enables the rear set of speakers no other options. I have the realtek drivers
Win 7 (7100)AMD Turion 64 MT-341Gb pc3200ATI MOBILITY RADEON X700 256Mb
Rock Quaddra T64
Win 7 (7100)
AMD Turion 64 MT-34
MICRO-STAR INTL CO.,LTD. Model MS-1036 Version 0291
1Gb pc3200
Realtek ALC 882, SoundBlaster™ Compatible, 4 channel speaker
USB2 webcam
Nearly identical problem here, rear speakers produce no output. I have a 4.0 system with 4 surround speakers and 1 subwoofer. Worked fine for the first five years or so I had the system and a SB Live! sound card. I've had to use stereo non-surround sound for the past four years, however, after the Live! sound card was replaced, and I'm trying to find a solution that will allow me to have surround sound again without shelling out money for an entirely new speaker set. Haven't had any luck locating a solution.
Windows 7 64-bitIntel(R) Core(TM) i7 CPU 920 @ 2.67GHz4.00 GB DDR3 RAMATI Radeon HD 5700 Series
Gigabyte Technology Co., Ltd. / EX58-UD3R
Windows 7 64-bit
Gigabyte EX58-UD3R
4.00 GB DDR3 RAM
Hyundai Imagequest L90D+
WDC WD 5000 AAKS-00V1A0 ATA
Antec 300
