SRS Premium Sound problem
  1. peq
    Win 7 Home Premium 64bit
    I' ve got a problem with my sound card driver. I have an Asus N61jv notebook win7 x64, with a Realtek HD Audio Driver and SRS Premium Sound Enhancement installed, but it doesn't work properly. I mean, SRS PS Control Panel works, doesn't display that I have incompatible device, detects plugged headphones, but it does nothing. I changing settings results in nothing but a slider movement, just like it wasn't turned on. Does anyone have an idea if this is fixable w/ reinstalling OS?
  2. Posts : 11,424
    Windows 7 Ultimate 64
    peq,
    Welcome to SF. Please see the link provided and confirm is this is the same driver your currently using?
    ASUSTeK Computer Inc.-Support-
    Sorry link won't take you to the audio driver which I was looking at but if you fill in info you will find it !
  3. peq
    Yes, I've already tried that one, and few others, with proper cleaning up after every install. But it still won't budge.
  4. Posts : 11,424
    Do you hear any audio though speakers or headphones?
  5. peq
    Yes, both sources are working. It's just that SRS won't make any improvement.
  6. Posts : 11,424
    So you want a placebo surround sound effect and can't get it to function?
  7. peq
    Well, I would disagree about 'placebo' effect of SRS enhancement. It used to work last time, when I listened to the music a week ago, when everything was alright and today I put on my headphones and noticed difference, so it isn't as placebo as you think. Anyway, I don't want to argue, I just want it to work.
  8. Posts : 11,424
    When I say placebo it is just an effect as a laptop has marginal sound as is and by creating this effect it makes the space between the speakers sound wider. Good news is you have sound. Bad news is an effect you had before has now gone away or has been turned off. When was the last time it worked and what updates/changes have been made or have you made since it worked?
  9. peq
    So just i little bit of confusion over 'placebo' meaning :)
    Well, I don't really know. I've been busy for a while, so I didn't have time to just sit and listen, so everything I can say, it used to work, and now it doesn't Windows kept updating all the time, none of other drivers were changed, didn't use any system messing software... I must admit, the os wouldn't mind a reinstall, but I want to find out what causes the problem...
  10. Posts : 11,424
    My point is if this happened two days ago then you could try a restore point earlier than that and see what that does? I also take it you know your way around the software and how to use it. Could by chance the effects be so subtle that you can't hear them over the internal speakers but with headphones or powered speakers it becomes clearer? Could the SRS have a slider which makes the amount of sound change vary and could this be set in a minimal setting? Lastly no offence was intended with "placebo" but merely that this is a effect and in such can only try to emulate a true multichannel surround sound system which of course it can't fully. Maybe "Pseudo" would have been a better word to use?
