How to keep audio output on when screen goes off?
Diesel Powered
2:41 PM
I've searched and haven't been able to come up with an answer.
On my old vista machine I could keep streaming audio while the screen went dark after 10min of no use. On the new 7 machine, the audio goes off if the monitor goes off and comes back on after moving the mouse to wake the monitor. Is there a way around this? I'd rather not have the monitor on for hours at a time when I'm not sitting in front of it.
Thanks in advance!
Windows 7 Home Premium 64bitAMD Phenom II 1045T Six-Core8GB DDR3ATI Radeon HD 5570 w/ 1GB DDR3 dedicated
HP HPE-410y
8GB DDR3
23" HD LCD
1T
It sounds like the PC is going into a standby state, not just the monitor.
RIGHT click in an empty space on the desktop (screen) and then click on "personalize". Then click on "Screen Saver" and when the panel comes up click on "Change Power Settings". You can set it so only the monitor is powered off after whatever time interval you want.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
That's a negative on the whole machine going to sleep. I've got it set to never sleep. When the monitor is off after 10min of no use and I move the mouse, the sound comes back instantly (actually faster than the screen lights back up). That's telling me that the live radio stream is still going in the background, but there must be a simple setting I'm missing somewhere that kills the actual audio output.
Anybody else?
HP HPE-410y
8GB DDR3
23" HD LCD
1T
Thats the only place I know to set what the PC does or how it works when in whatever power save mode.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Set the power controls to "High Performance", or set up a "Custom" plan, set the display to turn off "Never" and then switch the monitor off. That should keep the audio running. It works for me.
Check that your monitor itself is not set to sleep ( on the monitor, not on the PC).
Regards....Mike Connor
Several, including Windows 7 x64 Ultimate
I use winamp and stream all the time without a problem.
Check to see if your hard drive is powering down.
Screen saver: Blank
Wait: 10 minutes
Turn off the display: 20 minutes
Put the computer to sleep: Never
Turn off hard disk after: Never
Windows 7 Home Premium 64 bitIntel Core i7-4790G.SKILL 8GB (2 x 4GB) DDR3 F3-10666CL9D-8GBNTAMD Radeon R7 250
Intel Core i7-4790
GA-Z87X-D3H
AMD Radeon R7 250
Realtek ALC892
1920 x 1080, 1280 x 1024
WD5003AZEX
WD10EZEX
Samsung HD103SJ
Samsung 128 GB 840 PRO
SeaSonic M12II SS-500GM
Fractal Design Define R4
Zalman CNPS9900ALED
Logitech K800
Logitech M705
16 Mbps
A possible cause is using the speakers on your monitor
This is an old thread but still shows up in searches.
A likely cause is that you are using the speakers on your monitor. Some monitors, like mine, switch off the speakers when they stop receiving the video --- so you lose the sound!
It's nothing to do with windows 7 as the audio is still being output if you route it to separate speakers.
windows 7 professional 32 and 64 bit computers
I had the same problem as the starter of this thread, and what you wrote about the speakers on the display solved my problem.
My display is a Denon amplifier which receives sound and picture over HDMI.
  • In the Control Panels Power options I set the screen to never be turned off. (used to be 5 minutes.)
  • Then I selected an empty (black) screensaver that triggers after 5 minutes of inactivity.
Now the display seems to be off after 5 minutes but the sound is playing.
Thank you.
Windows 7 Ultimate 6 bitIntel
HTPC
Intel
Asus
[FONT=var(--theme-post-body-font-family]I had the same issue: My solution:
Go to power managment of Windows (Control Panel\Hardware and Sound\Power Options\Edit Plan Settings) and select: "Turn off the display" to Never. Then go to "Screen saver settings" and select "blank" and click on the item: "On resume, display logon screen" after X minutes you want to. This will keep your monitor screen "off" and music still playing through your monitor, as also your windows get locked for safety after Xmins.
[/FONT]
    windows Xp, 10, 11
    windows Xp, 10, 11
Turn off HDMI audio in the Nvidia control panel or whatever... It causes NOTHING but issues. Pipe your audio to real speakers and not the monitor or through HDMI or the Displayport connector.
HDMI and Displayports work well for home entertainment systems, but for computers I'd stay away from it... For me, I use a dedicated sound card and 5.1 audio...
Extra credit.
Amazon.com
YMMV Read the reviews...
