Windows 7: Reset Audio (Devices and or Settings)
08 Jan 2011   #1
Windows 7 64 bit
Lately I have been having some strange issues with my rear facing speakers on my monitor. It use to be I could hook the audio line into the back panel audio jack, but of late I need to place it in the front panel (for head phones) which becomes quite a hassle with having to take it out and put my head phones in...
Needless to say I would simply like to fix that, and it appears that reseting something, or re installing the monitor somehow... I don't know...
Ps. The weirdest part is when I plug in the headphones with the monitor plugged into the back both devices will work...
Similar help and support threads for2: Reset Audio (Devices and or Settings)
Audio Only out of one channel (multiple headsets and audio devices) Sound & Audio
Easily change settings for audio devices Sound & Audio
Solved Reset CMD to default settings? General Discussion
passwords reset its settings General Discussion
Realtek HD Audio/Motherboard Not recognizing any Audio Devices. Sound & Audio
Reset Connection Settings Network & Sharing
Is there anyway i can reset my proxy settings? Network & Sharing
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
