Sound Stuttering on Audio CDs
Cheemag
4:00 AM
Englandshire, Scotland
Two drives, E: & F:. F works fine.
E: stutters continuously when playing an audio CD. There is no problem with data, .MP3 etc, graphics/photos, only with audio CDs.
Device Manager tells me the drivers are up-to-date. Rebooting doesn't help.
Drive is a TSST CDDVDW SH-S223C ATA. Sound is on-board.
[Windows 7 Professional 64-bit, 4GB RAM]
Any ideas?
Windows 7 Professional 64-bitIntel Core 2 Duo4 GBNvidia GE Force 9500GT
Gigabyte
Intel Core 2 Duo
EP41T-UD3L
On-board
Acer V203H
Two Samsung HD103SJ 1TB
Fan
Do you have another DVD drive you can swap in to see if the issue disappears?
Have you done a system restore to a date before the problem began to see if it disappears?
Any recent software additions or changes in configuration?
DVD drives are commodities now. I don't know how long they can be expected to last, but I understand your reluctance to assume it is a bad drive.
Any chance you were multi-tasking at the time and putting a good load on the processor while playing the CD?
Dell S2340M 23 inch IPS
1600 x 900
Antec Solo II
Microsoft 200 6JH-00001 USB
Pale Moon
Thing is it's less than a year old and came with the machine, so still under warranty.
I've switched that off in favour of the Acronis image system, but I'm reluctant to restore before I've exhausted all other options.
Quite a few software additions, no changes in config.
The other drive, F: works perfectly so it could well be the drive. I don't ever remember playing an audio CD on E: before as I tended to use the F: drive for just about everything as it's faster.
Not the case as far as I know. It stuttered in a ripping programme as well as in Winamp. May be worth looking at what the CPU load is while playing audio.
Gigabyte
Intel Core 2 Duo
EP41T-UD3L
On-board
Acer V203H
Fan
OK. All I can suggest at this point is to start playing a disc, get it stuttering, then take a simultaneous look at processes in Task Manager to see what is loading up the processor and memory at that time.
I don't normally multi-task when I listen to music, but something else hogging the CPU and RAM is all I can think of at this time.
I assume this happens regardless of what playback program you are using?
1600 x 900
Antec Solo II
Pale Moon
Sounds like it's the drive. Look for a firmware update for the drive, if there is one. Swap data cables between the two drives and see if the drive works OK and/or the other drive now has the problem, in case it is a cable problem or a port problem. There are no drivers for CD/DVD drives other than the built in Windows drivers thus both drives are using the same driver.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Did that earlier, processor is relaxed during playback between 1% and 4%. At the moment, with nothing much running except Firefox, it's using 1.4GB of RAM out of 4GB. Seem a bit high? Goes up 1.46GB on the stuttering audio CD.
That is so: Winamp or VLC Media Player, same stutter. Actually more of a flutter than a stutter, i.e. a fast stutter!
I'm increasingly inclined to suspect the drive. Unfortunately I don't have a spare, short of taking one out of the Linux machine to swap and try.
Gigabyte
Intel Core 2 Duo
EP41T-UD3L
On-board
Acer V203H
Fan
I think what I'll do is buy another (and faster) drive and keep the present problem one as a spare and to experiment with it in another machine to determine if it really is knackered.
Gigabyte
Intel Core 2 Duo
EP41T-UD3L
On-board
Acer V203H
Fan
Sound Stuttering on Audio CDs [SOLVED]
I fitted a new Sony AD-7261S which solved the problem.
Thanks to all who responded.
Gigabyte
Intel Core 2 Duo
EP41T-UD3L
On-board
Acer V203H
Fan
