System Event - Changing sound makes a sound, how to mute it?
shantyman
5:48 PM
Pembroke, ON
Did my searching and couldn't find this one...
When I modify the speaker volume using the "Volume Mixer" icon, it generates a sound. When I adjust using the "Speakers/Headphones" icon, it does not make a sound.
I would like to mute the Windows 7 sound that happens when I adjust the sound, preferably without effecting the other system sounds? I can't find out which system 'event' it is that causes a sound to be generated when I modify the speaker volume. I'd like to mute it, i.e. no sound when I change the volume.
thanks
Windows 7 Home Premium 64bitPentium T4300
Dell Inspiron 1545
Pentium T4300
Windows 10, Home Clean InstallIntel Core2 processsor Q8200(2.33Ghz 1333FSB)...6 gbATI Radeon 256MB HD3650
Dell XPS 420
6 gb
Intergrated 7.1 Channel Audio
Dell SP2009W 20"
640 GB Serial ATA Hard drive
Fan
Dell USB Keyboard
Dell Premium Optical USB
DSL 2.85
well its not in that tutorial that I could see either...
Using the "Sound" control panel, in the list of "Program Events" that you can assign a sound to, there is no entry for "Change Volume" which is what I would like to see...
Dell Inspiron 1545
Pentium T4300
"System Sounds" adjustment is not sufficient?
Windows 7 Home Premium 64 bitIntel Core i7-4790G.SKILL 8GB (2 x 4GB) DDR3 F3-10666CL9D-8GBNTAMD Radeon R7 250
Intel Core i7-4790
GA-Z87X-D3H
AMD Radeon R7 250
Realtek ALC892
1920 x 1080, 1280 x 1024
WD5003AZEX
WD10EZEX
Samsung HD103SJ
Samsung 128 GB 840 PRO
SeaSonic M12II SS-500GM
Fractal Design Define R4
Zalman CNPS9900ALED
Logitech K800
Logitech M705
16 Mbps
Isn't it the 'default beep' sound?
Windows 7 Ultimate (SP1)AMD Sempron 3600+ATI Radeon Xpress 1150
Vostro
AMD Sempron 3600+
1200 x 800
WD Scorpio Blue 500 GB
