Solved Another No Audio Output Device Is Installed thread
alkemy007
8:25 AM
I have tried lots of the fixes other people have mentioned in similar threads but to no avail. Ill list my problem and what I have tried and see if there is any other workarounds I can do.
Problem: I have no sound coming from my speakers at all on my PC. I have a speaker icon with a red cross next to it.
What I have tried:
I tried looking in device manager but the sound and video controllers tab does not even appear.
I open up the sound tab in control panel but it says no audio devices are installed, even with the "show disabled devices installed" option checked.
I have tried installing realtek drivers. One thing. When I look in control panel I have two realtek things listed. They are 1: Realtek AC'97 Audio and 2: Realtek High Definition Audio Driver. Do they conflict?, shall I uninstall one?.
Just a history of my PC. It is an Advent 3219 that was originally Windows XP. I now have Windows 7 on there. I am not sure if the sound stopped directly after installing Windows 7 because my younger brother had the PC originally and he didnt notice (!).
Are there any ways I can fix this, it is driving me crazy, thanks in advance for all the help.
Windows 78gb
Custom build
8gb
Have you tried the troubleshooters in Control Panel?
Control Panel\All Control Panel Items\Troubleshooting\Hardware and Sound.
Try the playing audio, and Hardware Devices.
Originally Win 7 Hm Prem x64 Ver 6.1.7600 Bui...Intel i3 530 2.93GHz, 2933MHz 2 Cores 4 Logic...6GB of 1,333MHz DDR3 SDRAM32MB Intel Graphics Media Accelerator HD IGChip
Gateway H57M01 133 megahertz
1600 x 900 x 59 hertz
300watts.
Mid-Tower Desktop
Stock from Gateway
System Specs by Belarc.
Canon Pixma MG3222 Printer.
I tried what you said and it comes up with a dialog box that says
"Troubleshooting has completed"
The troubleshooter has made changes to your system. Try attempting the task you were trying to do before.
Problems found: Hardware changes might not have been detected. Detected.
I try playing a song and windows media tell me that there is a problem with my sound device.
I also still have the red x on my speaker icon too.
Windows 78gb
Custom build
8gb
It is quite possible that they are conflicting. found the specs for your computer here,
UKT Support - Advent 3219 PC
which shows it has the Realtek AC'97 audio on it, so the HD driver shouldn't work with it. Taking it a step further the motherboard in it is this one,
ECS Web Site
which shows it is the Realtek ALC655 AC'97 audio. I would start with uninstalling both, then installing the latest from Realtek for it,
Realtek
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
Thanks Stormy, you took the words right out of my mind. ;)
I just got back from chores, and after thinking 'bout this, I was also going to suggest updating the drivers next because of the upgrade from XP to 7.
Thank You for the input!
300watts.
Mid-Tower Desktop
Stock from Gateway
An update:
I uninstalled both realtek programs, restarted my pc, and went and download the installer package that you linked a post or two above. The problem is when I go to install it, it starts up and says its loading the drivers but windows security pops up and says that the driver is not recognised. I choose install anyway and it seems to carry on but a minute or so later the same dialog pops up. This carries on and on and the progress bar on the install don't go any further, just the same thing. Dialog box-install anyway...minute or so...dialog box-install anyway etc etc. This is so frustrating lol
Windows 78gb
Custom build
8gb
When you right click on the installer package, do you see "Run as administrator"?
Click on that, and see how it goes.
300watts.
Mid-Tower Desktop
Stock from Gateway
Yep, tried that. Same windows security box popping up.
Windows 78gb
Custom build
8gb
I would like you to try a complete shutdown:
  • Turn off your PC.
  • Unplug it.
  • Unplug all your devices from your PC, and any power supplies.
  • Touch the power on button as if you want to start the PC. This will discharge any residual power left in the PC. (Capacitors) You may even see the power indicator light come on for a few moments.
  • Wait 30 minutes or more.
  • Plug in your essential USB devices (keyboard, mouse).
  • Plug in your PC, turn it on.
  • Try re-installing the drivers.
  • Restore any of the rest of your USB devices.
300watts.
Mid-Tower Desktop
Stock from Gateway
  • Turn off your PC.
  • Unplug it.
Tried that but I still luck out with the windows security dialog box keep popping up when Im trying to install the realtek drivers :(
Windows 78gb
Custom build
8gb
Is the onboard audio enabled in the BIOS?
Windows 7 Home Premium 64 bitIntel Core i7-4790G.SKILL 8GB (2 x 4GB) DDR3 F3-10666CL9D-8GBNTAMD Radeon R7 250
Intel Core i7-4790
GA-Z87X-D3H
AMD Radeon R7 250
Realtek ALC892
1920 x 1080, 1280 x 1024
WD5003AZEX
WD10EZEX
Samsung HD103SJ
Samsung 128 GB 840 PRO
SeaSonic M12II SS-500GM
Fractal Design Define R4
Zalman CNPS9900ALED
Logitech K800
Logitech M705
16 Mbps
Windows 78gb
Custom build
8gb
What mobo are you using?
Intel Core i7-4790
GA-Z87X-D3H
AMD Radeon R7 250
Realtek ALC892
WD5003AZEX
WD10EZEX
Samsung HD103SJ
Zalman CNPS9900ALED
Logitech K800
Logitech M705
16 Mbps
Im guessing that means Motherboard?. If so, I just used aida and it says my motherboard name is: Abit SG-72/ECS 661FX-M (Deluxe)
Hope that helps.
Windows 78gb
Custom build
8gb
Linked too back in post #4.
To get in the bios, while the POST screen is showing hit the Del/Delete key. Then using the arrow keys navigate to the "Integrated peripherals" section and in there go to "SIS OnChip PCI Device" and you will find the setting for the onboard audio.
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
Yeeeeee Ha. Got it!. The option was unchecked in my bios. As soon as I booted up the red cross was there again and I thought I was out of luck but the PC automatically started downloading drivers and now Im back with sound. Thanks a lot everyone who took their time to try and sort my problem out. stormy13, your a star.
Windows 78gb
Custom build
8gb
Glad to hear you have it fixed alkemy007! I've been a little slow these past few weeks.
Thanks to p5bdkw for the lead on the Bios check, and thanks to stormy13 for pitchin' in.
300watts.
Mid-Tower Desktop
Stock from Gateway
Anak,
Thank for the props.
I appreciate it!:)
I too am glad it worked out for alkemy007.
Intel Core i7-4790
GA-Z87X-D3H
AMD Radeon R7 250
Realtek ALC892
WD5003AZEX
WD10EZEX
Samsung HD103SJ
Zalman CNPS9900ALED
Logitech K800
Logitech M705
16 Mbps
Anak,
I appreciate it!:)
Your most welcome!
It is up amongst the leaders, but yes there is nothing worse than a mis-behavin' communications device.
Unless it's being Derezzed.
300watts.
Mid-Tower Desktop
Stock from Gateway
