Static background noises with my headset plugged in to sound card
midnitemaximum
4:30 PM
Hey guy, I have an annoying problem with my Steelseries 7H headset. When I connect my headset to my sound card via front panel, I hear static background noises like when I scroll the mouse, I can actually hear it in my headset speakers, its very low and staticy but I can hear it, when I turn up all the volume, the static is clearly there.
Any help would be appreciated.
Also my case is an Antec 300.
Windows 7 Ultimate x64AMD Phenom II X4 920 3.2GHZG.SKILL 4GB DDR2 800XFX RADEON 5770
ASUS M3N72-D
XFX RADEON 5770
X-FI TATANIUM 5.1
ASUS 20"
SAMSUNG SPINPOINT F1 1TB, SAMSUNG SPINPOINT F3 1TB
ANTEC EARTHWATTS 650W
ANTEC 300
AIR
G110
COOLER MASTER STORM SENTINEL
CABLE
Probably find it is due to poor or no shielding in the cables from the front panel to the card, a common occurrence in a lot of cases. One way to test is with the headset plugged into the front jacks, move the cable inside around and listen if the static becomes less.
No resolution but one of the people in this thread,
Front Panel Audio Problems - Audio-Technology - Audio
had the same problem. You can see from this,
shield front panel audio cable - Google Search
that it is a fairly common problem.
By the way do you get the same static when you connect the headset directly to the card? If not that is also a good indication of poor shielding in the front panel cable (and hopefully not in the front panel itself). If it comes down to it you could always try this,
How-To: Front Panel Audio Noise Reduction
to shield the cable and see if that reduces or stops the static.
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
I get a hum when I plug into the headphone jack of the case, but when I plug into the Logitech headphone jack of the volume control, the sound is crystal clear and hum-free.
I too would suggest shielding.
Windows 7 Home Premium 64 bitIntel Core i7-4790G.SKILL 8GB (2 x 4GB) DDR3 F3-10666CL9D-8GBNTAMD Radeon R7 250
Intel Core i7-4790
GA-Z87X-D3H
AMD Radeon R7 250
Realtek ALC892
1920 x 1080, 1280 x 1024
WD5003AZEX
WD10EZEX
Samsung HD103SJ
Samsung 128 GB 840 PRO
SeaSonic M12II SS-500GM
Fractal Design Define R4
Zalman CNPS9900ALED
Logitech K800
Logitech M705
16 Mbps
Thanks guys, I've seem to have fixed it. It seems that this is a common problem amongst Antec cases. If anyone else has a problem regarding their front audio and has an Antec case, I suggest reading this guide or try one of stormy13's methods.
inCrysis - Crysis Forums / Antec 300 Front Panel Audio Ground Loop
It was fairly simple and took me a few minutes, only my grounding wire wasn't orange or white, it was gray.
Thanks again.
ASUS M3N72-D
XFX RADEON 5770
X-FI TATANIUM 5.1
ASUS 20"
ANTEC 300
AIR
G110
CABLE
