W7 x64 - poor sound levels
Blok23
7:48 PM
Hi people!
When I install latest Realtek drivers I'm getting 50% lowest sound than I had before I've formatted my OS, also the same version of drivers and OS.
I'm running W7 x64 and Asus P5Q - PRO mb.
When I uninstall them and install "default Windows7 Realtek HD drivers" sound is great and high like before.
How can I solve this problem because I tried every to combine with every settings in Realtek HD audio manager but with no success?
Windows volume panel > Playback devices > Speaker > Properties > Levels > Realtek HD Audio Output
What does your output level look like?
Is it at the maximum?
Realtek also has Loudness Equalization which will boost the volume quite a bit.
Windows 7 Home Premium 64 bitIntel Core i7-4790G.SKILL 8GB (2 x 4GB) DDR3 F3-10666CL9D-8GBNTAMD Radeon R7 250
Intel Core i7-4790
GA-Z87X-D3H
AMD Radeon R7 250
Realtek ALC892
1920 x 1080, 1280 x 1024
WD5003AZEX
WD10EZEX
Samsung HD103SJ
Samsung 128 GB 840 PRO
SeaSonic M12II SS-500GM
Fractal Design Define R4
Zalman CNPS9900ALED
Logitech K800
Logitech M705
16 Mbps
p5bdkw:
I notice that your screen shot shows a "stereo mix" option.
Can you confirm that the "stereo mix" functionality works on your PC with W7 Home Premium 64---that is, can you record whatever you might be listening to on your speakers or headphones at any given moment?
I ask because I am going to be migrating to a motherboard with Realtek audio and Win 7 64-bit shortly.
"Stereo mix" is very hit and miss on Windows 7---many sound drivers simply do not support it. So I'd like some confirmation about your situation.
Do you specifically have Realtek ALC892 onboard sound???
Dell S2340M 23 inch IPS
1600 x 900
Antec Solo II
Microsoft 200 6JH-00001 USB
Pale Moon
Ignatzatsonic,
I can confirm that I was able to record Winamp, WMP and SageTV using Audacity.
Now, the stereo mix pages shows 4 sample rates relating to CD, DVD and Studio quality.
16 bits 44100 Hz CD Quality
16 bits 48000 Hz DVD Quality
16 bits 69000 Hz Studio Quality
16 bit 192000 Hz Studio Quality
I can't confirm that if you use any of the higher rates, that they will be recorded at those rates.
I have the Realtek ALC889 chipset.
Intel Core i7-4790
GA-Z87X-D3H
AMD Radeon R7 250
Realtek ALC892
WD5003AZEX
WD10EZEX
Samsung HD103SJ
Zalman CNPS9900ALED
Logitech K800
Logitech M705
16 Mbps
Ignatzatsonic,
Good info, thanks. My new mobo will have ALC892 which I can only hope has the same capabilities.
I use Audacity as well and use the 44100 setting without any problems, so would stick with that.
Generally speaking--do you have any issues with Realtek overall--glitches, sound quality, functionality, configurability, driver support, Realtek website, etc???
1600 x 900
Antec Solo II
Pale Moon
No. But, I think that with different hardware setups, you run into different problems. I just installed 4 Windows updates and SageTV went wacky. Two reboots seemed to fix the problem. Realtek releases drivers very frequently, I'm not sure that's a good thing. Hardware, drivers and Windows updates, not always a good mix.
Good luck!!
Intel Core i7-4790
GA-Z87X-D3H
AMD Radeon R7 250
Realtek ALC892
WD5003AZEX
WD10EZEX
Samsung HD103SJ
Zalman CNPS9900ALED
Logitech K800
Logitech M705
16 Mbps
