Windows 7: Advanced Audio Settings/Controls
14 Jan 2011   #11
I'm assuming you both can read this post and could also read my above post (#9), so it must be the fact that I originally wrote the IDT and RealTek Sound Settings information in a Word doc and cut and pasted into the Message Reply box. Can't imagine why that would happen, but it apparently did, so there you have it. . .
24 Sep 2013   #12
Windows 7 Ultimate 64bit
Hi guys, any more info on how to get more advanced settings? I have the same question as Fuzz Ball, but my motivation is to take advantage of multiple audio devices.
I have an L502x windows7 home edition, dell's realtek options do not allow disabling of jack detection, and I'd like to specifically (first!) keep playing audio on one application (mediamonkey) through speakers (built-in, awesome) while using speakers plugged in to (either) headphone socket to simultaneously play audio from another app (chrome)
I've done the mapping apps to devices before, guess the system had a better soundcard that supported this...
How do I find out which soundcard I have and whether it support the feature I'm describing?
someone found a solution, but I don't know where this was achieved, or if my spec will allow... 2 headphone jacks? surely I must be able to have multi-speakers!?!
optimistic 'J
solved the problem with different output to the front panel on my ASUS P5P43TD.
All you need to do is to go to Onboard Devices Configuration in BIOS settings and change Front Panel Type from HD Audio to AC97
After restarting you have now Tab called HD Audio 2nd output in Realtek Audio Manager (but keep Speakers tab as default output).
If you can't see that Tab, go to Device Advanced Settings and change it to Make Front and Rear output devices playback two different audio streams simultaneously. If you choose the other option in Advanced, you will have only one stream but from both outputs - front and rear.
And now you have multiple choice for output in popular applications such as audoi- and video-players, where you can change output to Speakers or to HD Audio 2nd output.
As a result my Foobar2000 (audio) and MPC (video) are playing onto different outputs as I'm typing this post.
For some games you can choose the output too (Black Ops) in game Sound options but in some of them you cannot (MW II) BTW if you don't set anything as Default in Realtek Audio Manager you won't have any sound in MW II and some other games.
12 Nov 2014   #13
any l502x owners anywhere that can confirm whether this is "normal" (abundance of "unplugged devices" when connecting a single samsung lcd tv via hdmi....)
data from nirsoft's soundvolumeview
thanks in advance.
Search this Thread:
Advanced Search
Missing power state controls in advanced power plan settings
Hi guys, I'm new here and this is my first post. I have an Optiplex 745 running Windows 7 Professional. Normally in the advanced setting section of the power plan option I have the option to change the power state, however all of a sudden these options have just totally disappeared. Any help is...
General Discussion
Realtek HD audio manager interface not showing advanced settings
Thank's for looking. I have a Asus-G74sx-91234z laptop,last week when i plugged in headphone i started to hear sound coming from both headphone and the laptop speakers,a quick google search told me change some settings in Realtek HD audio manager,when i opened the user interface i found my realtek...
Cannot see Multimedia Settings under "Change advanced power settings"
I have already clicked "Change settings that are currently available" but it still does not show it, restarted the PC and still same result. MSE disabled Windows 7 Starter 32-bit Power Plan: High Performance System Model: HP Mini 110-3500
General Discussion
Unable to make changes parental controls settings
I am logged in as the only administrator on my Home Premium laptop. I created an account as a standard user but i am unable to change its controls. It's kinda strange because it allowed me to change the time limits but when i try to set the "game ratings" or the "program limits" on, i get this...
General Discussion
Can't access or open User Account Controls settings
I diabled UAC today because I wanted to delete some files. However, it didn't work so I went back and tried to click on UAC to enable it again, but I can't. The UAC window doesn't pop up. All it does is give a small flash on the screen, if you know what I mean. Help please! I also created a new...
General Discussion
Unable to make change to parental controls settings.
If this problem perisists, see your system administrator. Of course, I AM the system administrator. Of course, Microsoft SHOULD say "ask the SevenForums", but it doesn't. Sidebar aside, why am I getting this message? 1. I AM using the actual ADMINISTRATOR account. I have the problem even...
System Security
