Advanced Audio Settings/Controls
  1. Posts : 31
    Windows 7 Home Premium 64-bit
    This isn't so much a problem as more of something I'd like to know about. I'm curious as to whether there are advanced audio controls in Windows 7 somewhere, something like XP's controls where you could control the wav and all sorts of different audio levels. Wanting to know because with earphones in, I have to lower my volume level to 1, and even thats a bit loud.
    The alternate is whether theres any settings in Realtek (the one you get with 7), that do the same/similar thing. Thanks
  2. Posts : 1,996
    Windows 7 Home Premium 64 bit
    Yep
    Open the Microsoft volume mixer, select the device, properties and you can bring up quite a few adjustments.
    Just an example:
    "What U Hear" Recording - Enable
  3. Posts : 2,578
    Vista 64 bit and 32 bit (SP2)
    This is how you do the sound settings for IDT Audio and RealTek in Vista, and I believe Windows 7 is the same or very similar:
    Initial Settings:
    Go to Control Panel, Sound, “Speaker + Dual Headphones”
    Should have green check mark and say: Working
    Select: Playback, Recording or Sounds
    Double-click for settings, and choose all settings (including “Room Enhancements”)
    To Boost or Lower the Volume:
    1. Right click on "speaker/volume icon" on the right lower corner of Desktop.
    2. Click "Playback devices"
    3. Under Playback Tab, click "Speakers + Dual Headphones, and then click "Properties"
    4.Under Enhancements Tab, scroll down + check on "Loudness Equalization", then click Apply + OK
    Go to Control Panel + open IDT Audio, Playback
    Click on: Settings, and choose your setting options
    Then click on: Setup and choose your setting options
    To Balance Speakers:
    Go to IDT Audio, select Setup
    Laptop speakers: Sound, “Speaker + Dual Headphones”
    Click on: Settings, and choose all settings
    Then click on: Setup and choose all settings
    Headphone settings:
    “Independent Dual Headphones”
    For Playback
    Settings
    Check: set as default
    Bass Management – have set at the maximum
    Optimize Bass Routing – have it selected (button turns green)
    Independent Dual Headphones is the middle one
    Sound Mixing for Headphones
    Go to Control Panel + open Sound
    Select Independent Dual Headphones + double-click on it
    To adjust base: Go to Enhancements + check Bass Boost + Low Frequency Protection, + then go down to Settings and try different settings.
    Same for Headphone Virtualization and Loudness Equalization
    In left-hand column, select: Equalization, and choose settings
  4. Posts : 31
    Thanks p5bdkw, it helped greatly. Found what I need to change.
    Also Imperfect1, thanks for the post, but I can't see the text well... its all black :P meaning I have to highlight it to read. But nonetheless, problem solved .
    Thanks guys
  5. Posts : 2,578
    Thanks guys
    Glad you solved your problem Fuzz Ball, but I'm really puzzled by your comment. Why would the text be all black? You can't see the text, and you have to highlight it? I'm really confused, because it looks perfectly clear and normal to me. Would you mind very much taking a screen shot so that we can see what you mean? Thanks very much.
  6. Posts : 31
    It's black text on black background for me. :P
    Attached Thumbnails Attached Thumbnails Advanced Audio Settings/Controls-black-text.jpg
  7. Posts : 2,578
    Jeez, I've never heard of anything like that. I wonder why one post on a forum would appear any different than any other post on your system? It's not like the forum poster can control your system! I can understand the font being different, of course, but the background color on your screen? That's a real mystery!
  8. Posts : 31
    I'm using the pitch black setting... what colour does the background and text appear to you?
  9. Posts : 2,578
    I'm using the Seven Forums default theme: (SF Default CDN)
    My background is a pale, pale blue, almost white. Text is black.
  10. Posts : 12,012
    I couldn't read it on my screen either---black on black.
