Advanced Audio Settings/Controls
Fuzz Ball
7:21 AM
Melbourne, Australia
This isn't so much a problem as more of something I'd like to know about. I'm curious as to whether there are advanced audio controls in Windows 7 somewhere, something like XP's controls where you could control the wav and all sorts of different audio levels. Wanting to know because with earphones in, I have to lower my volume level to 1, and even thats a bit loud.
The alternate is whether theres any settings in Realtek (the one you get with 7), that do the same/similar thing. Thanks
Windows 7 Home Premium 64-bitIntel i5 450 @ 2.4GHz4GB DDR3 1066MHzATi Mobile Radeon HD5870 1GB vDDR5
msi GX740-235US
Unknown
4GB DDR3 1066MHz
On-board Realtek HD Audio
17" WSXGA+
Western Digital 320GB 7200 RPM
Unknown
msi GX740 Laptop Case
Unknown
Full laptop keyboard (including Numpad)
Logitech G500
18.75Mbps DL, 0.49Mbps UP (Cable). ISP upload limits.
My graphics card says its a 5870, my processor says its an i5 and my ram says its 4GB. What's to say that they're not actually this? MY PARTS MIGHT BE FOOLING ME.
Windows 7 Home Premium 64 bitIntel Core i7-4790G.SKILL 8GB (2 x 4GB) DDR3 F3-10666CL9D-8GBNTAMD Radeon R7 250
Intel Core i7-4790
GA-Z87X-D3H
AMD Radeon R7 250
Realtek ALC892
1920 x 1080, 1280 x 1024
WD5003AZEX
WD10EZEX
Samsung HD103SJ
Samsung 128 GB 840 PRO
SeaSonic M12II SS-500GM
Fractal Design Define R4
Zalman CNPS9900ALED
Logitech K800
Logitech M705
16 Mbps
This is how you do the sound settings for IDT Audio and RealTek in Vista, and I believe Windows 7 is the same or very similar:
Initial Settings:
Go to Control Panel, Sound, “Speaker + Dual Headphones”
Should have green check mark and say: Working
Select: Playback, Recording or Sounds
Double-click for settings, and choose all settings (including “Room Enhancements”)
To Boost or Lower the Volume:
1. Right click on "speaker/volume icon" on the right lower corner of Desktop.
2. Click "Playback devices"
3. Under Playback Tab, click "Speakers + Dual Headphones, and then click "Properties"
4.Under Enhancements Tab, scroll down + check on "Loudness Equalization", then click Apply + OK
Go to Control Panel + open IDT Audio, Playback
Click on: Settings, and choose your setting options
Then click on: Setup and choose your setting options
To Balance Speakers:
Go to IDT Audio, select Setup
Laptop speakers: Sound, “Speaker + Dual Headphones”
Click on: Settings, and choose all settings
Then click on: Setup and choose all settings
Headphone settings:
“Independent Dual Headphones”
For Playback
Settings
Check: set as default
Bass Management – have set at the maximum
Optimize Bass Routing – have it selected (button turns green)
Independent Dual Headphones is the middle one
Sound Mixing for Headphones
Go to Control Panel + open Sound
Select Independent Dual Headphones + double-click on it
To adjust base: Go to Enhancements + check Bass Boost + Low Frequency Protection, + then go down to Settings and try different settings.
Same for Headphone Virtualization and Loudness Equalization
In left-hand column, select: Equalization, and choose settings
Vista 64 bit and 32 bit (SP2)Intel(R) Core(TM)2 Duo Processor T9400 (2.53 GHz4GB DDR2 System Memory (2 Dimm)512 MB NVIDIA GeForce 9600M GT
Built-in HP
Max
Thanks p5bdkw, it helped greatly. Found what I need to change.
Also Imperfect1, thanks for the post, but I can't see the text well... its all black :P meaning I have to highlight it to read. But nonetheless, problem solved :D.
Thanks guys
msi GX740-235US
Unknown
4GB DDR3 1066MHz
17" WSXGA+
Unknown
Unknown
Logitech G500
Thanks guys
Glad you solved your problem Fuzz Ball, but I'm really puzzled by your comment. Why would the text be all black? You can't see the text, and you have to highlight it? I'm really confused, because it looks perfectly clear and normal to me. Would you mind very much taking a screen shot so that we can see what you mean? Thanks very much.
Built-in HP
Max
It's black text on black background for me. :P
msi GX740-235US
Unknown
4GB DDR3 1066MHz
17" WSXGA+
Unknown
Unknown
Logitech G500
Jeez, I've never heard of anything like that. I wonder why one post on a forum would appear any different than any other post on your system? It's not like the forum poster can control your system! I can understand the font being different, of course, but the background color on your screen? That's a real mystery!
Built-in HP
Max
I'm using the pitch black setting... what colour does the background and text appear to you?
msi GX740-235US
Unknown
4GB DDR3 1066MHz
17" WSXGA+
Unknown
Unknown
Logitech G500
I'm using the Seven Forums default theme: (SF Default CDN)
My background is a pale, pale blue, almost white. Text is black.
Built-in HP
Max
I couldn't read it on my screen either---black on black.
Dell S2340M 23 inch IPS
1600 x 900
Antec Solo II
Microsoft 200 6JH-00001 USB
Pale Moon
I'm assuming you both can read this post and could also read my above post (#9), so it must be the fact that I originally wrote the IDT and RealTek Sound Settings information in a Word doc and cut and pasted into the Message Reply box. Can't imagine why that would happen, but it apparently did, so there you have it. . .
Built-in HP
Max
Hi guys, any more info on how to get more advanced settings? I have the same question as Fuzz Ball, but my motivation is to take advantage of multiple audio devices.
I have an L502x windows7 home edition, dell's realtek options do not allow disabling of jack detection, and I'd like to specifically (first!) keep playing audio on one application (mediamonkey) through speakers (built-in, awesome) while using speakers plugged in to (either) headphone socket to simultaneously play audio from another app (chrome)
I've done the mapping apps to devices before, guess the system had a better soundcard that supported this...
How do I find out which soundcard I have and whether it support the feature I'm describing?
someone found a solution, but I don't know where this was achieved, or if my spec will allow... 2 headphone jacks? surely I must be able to have multi-speakers!?!
optimistic 'J
solved the problem with different output to the front panel on my ASUS P5P43TD.
All you need to do is to go to Onboard Devices Configuration in BIOS settings and change Front Panel Type from HD Audio to AC97
After restarting you have now Tab called HD Audio 2nd output in Realtek Audio Manager (but keep Speakers tab as default output).
If you can't see that Tab, go to Device Advanced Settings and change it to Make Front and Rear output devices playback two different audio streams simultaneously. If you choose the other option in Advanced, you will have only one stream but from both outputs - front and rear.
And now you have multiple choice for output in popular applications such as audoi- and video-players, where you can change output to Speakers or to HD Audio 2nd output.
As a result my Foobar2000 (audio) and MPC (video) are playing onto different outputs as I'm typing this post.
For some games you can choose the output too (Black Ops) in game Sound options but in some of them you cannot (MW II) BTW if you don't set anything as Default in Realtek Audio Manager you won't have any sound in MW II and some other games.
Windows 7 Ultimate 64bit2.28GbNVIDIA
8Gb
NVIDIA
built in pad || iphone || MS wireless
100MB
Chrome, Chrome portable
any l502x owners anywhere that can confirm whether this is "normal" (abundance of "unplugged devices" when connecting a single samsung lcd tv via hdmi....)
data from nirsoft's soundvolumeview
thanks in advance.
8Gb
NVIDIA
100MB
