No Sound - Compaq Laptop/ Build 7100 (64-Bit)
somavirex
7:21 PM
Here's what I have:
Compaq Presario V5210US
Windows 7 Build 7100 (64-bit)
In hardware tabs, there's an error code 28 next to the audio adapter.
Hardware ID's for Sound Card:
PCI\VEN_1002&DEV_4370&SUBSYS_30AE103C&REV_02
PCI\VEN_1002&DEV_4370&CC_040100
Any assistance would be greatly appreciated.
Thanks!
error code 28
Here's what I have:
Thanks!
Hi
According to M$ an error code 28 means device driver not installed here is the info
http://support.microsoft.com/kb/125174
Find the driver for your sound card at the mfr and install it make sure you get 32 bit if you are or 64 bit in you are 64 bit
Hope this helps
Ken
HP Pavillion dv-7 1005 Tx
Win 8 Release candidate 8400
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
I've tried installing the 64 bit version of the drivers provided by Compaq, to no avail. The drivers claim to have installed, Windows reboots, nothing happens, same error message.
The only versions available are for Vista or XP; the do not list support for Windows 7 yet.
I am therefore looking for a workaround. If anyone knows a specific driver that will work for the 64 bit Windows 7 for the given hardware ID's I'd appreciate it.
Thanks though, Ken.
i am having the same problem, although i am running the 32-bit vers.
same audio card. its a Conexant AC-Link audio, but anytime i try to update the drivers, they fail.any help would be appreciated.
windows 72 GHZ1 GBATI RADEON XPress 200m
Compaq Presario laptop
windows 7
2 GHZ
1 GB
80 GB
@ original poster Have you tried downloading the driver to your desktop> then open it find the setup.exe file. click on properties> you'll see a run in compatibility mode box, check it, then choose either Xp sp2 or Vista. Go into device mngr slect device then update driver> find it yourself> point it ot the desktop and have it instasll it> reboot and see if it works
Windows 7 ultimate 64 bit / XP Home sp3intel Core 2 Duo E8400 3.0ghz8 gigs 1066 OCZ Fata1tyEVGA GTX 580 Call of Duty Black Ops Edition
Asus P5ND bios 1401
Asus 24in LCD's 2MS X2
1920x1080p @60Hz
OCZ 700W GameXtreme
NZXT Apollo
Download 19.83 Upload 0.97
i have figured it out.
here is the driver "http://driverzone.com/device.php?id=72038"
note: it needs to be run in compatibility for this version of windows which "7" will figure out after its first fail, and sry the above link isnt a hyperlink but my html skills are rusty.
SCRATCH THAT, i thought it worked at first, but in reality it doesnt... =[
windows 7
2 GHZ
1 GB
80 GB
