Installed win 7 64 bit now sound wont work
  1. Posts : 14
    xp pro 32 bit
    Hi i have a sound blaster Audigy 24 bit advanced HD sound card. It worked fine while i had xp installed but i have now gone to 64bit windows 7 and be buggered if i can get it to work.
    I can not seem to find the right driver for 64 bit. Have tried a couple of downloads but they just gave me an error. I have disabled the on board sound and this was infact done about 6 months ago. I rechecked the bios and it is still disabled. The error i am getting is
    This device cannot find enough free resources that it can use. (Code 12)
    If you want to use this device, you will need to disable one of the other devices on this system.
    I have no other sound devices listed and onboard has been disabled....Hope someone can help.
    As a side note it is NOT a sound blaster LIVE
  2. Posts : 19,383
    It's probably the lack of x64 driver that is causing issues I would guess?
    Please take a screen capture image of the relevent device under Device Manager, as shown in the image below. Does it show up? Does it have a yellow exclamation mark under it? Is your on-board sound card still shown?
    Also try this : Download Speccy and run it. Click the Audio section, and take a screen capture of that and post it here too please.
    Regards,
    Golden
    Attached Thumbnails Attached Thumbnails Installed win 7 64 bit now sound wont work-capture.png
  3. Posts : 14
    xp pro 32 bit
    Hi thanks for the reply. At the moment my computer is at the tech shop being fixed. I was getting BSOD trying to install nortons. I ran memory test and uninstalled updates, uninstalled generic sound drivers and still BSOD. Suspect it is a driver issue with the mobo. Kn9s is what the box says and what it looks like but motherboard says kn9 ultra so decided off to the technician and let them do it. I think it needed a bios update so i will let them do it. I will report back once it comes back hopefully they will get the sound sorted while its there....
  4. Posts : 14
    xp pro 32 bit
    Hi I'm back again. New stick of ram giving me issues. That is now fixed but alas still no sound. I have downloaded speccy and here is a screen capture.
    I have a kn9s mobo amd athlon 3500+ 64
    I have on board sound disabled in the bios. The on board sound is realtek hd audio but it was a bit unstable at times so 6 months or so ago i brought a sound blaster Audigy 24-bit advanced HD (it does not say live 24-bit)
    I hope someone can help me. I have let windows update install new drivers but that did not work. I also let the creative auto update try to update but still no sound. I have a feeling it could be mobo drivers as the disk that came with my board wont install due to no windows 7 drivers? I went to abit and downloaded the 64 bit drivers but they were for Vista but that still did not help (chipset drivers that is). Oh well here's hoping someone can help......
    Attached Thumbnails Attached Thumbnails Installed win 7 64 bit now sound wont work-spekky.jpg   Installed win 7 64 bit now sound wont work-untitled.jpg
  5. Posts : 19,383
    Is your on-board sound (the one you disabled in the BIOS) shown as uninstalled under Device Manager? If not, you need to uninstall the on-board, then reinstall the new sound card.
    Regards,
    Golden
  6. Posts : 14
    xp pro 32 bit
    When i upgraded to win 7 64 bit i never installed the realtek drivers. The only sound i have installed is the sound blaster sound card. On board sound was disabled when i had xp sp3 as well as the realtek drivers. The realtek drivers have never been installed on win 7.
  7. Posts : 14
    xp pro 32 bit
    Yes i have done the windows update to install drivers (that was said in my post) and i still have no sound. The sound card was working perfectly with xp sp3. The only thing that changed was going from xp sp3 32 bit to win 7 64 bit. Everything else is working fine i just have no sound.
  8. Posts : 14
    xp pro 32 bit
    This is what is in my control panel
    Im guessing it should not be 32 bit as i have win 7 64 bit
    Attached Thumbnails Attached Thumbnails Installed win 7 64 bit now sound wont work-control-panel.jpg
  9. Posts : 14
    xp pro 32 bit
    Hi, I have gone back to on board sound which was realtek HD audio. Although i can not install the realtek audio manager from the disk and when i tried to install the program from abit it only has vista 64 drivers. Well at least for now i have sound that is working with win 7 drivers that will do until i decide if i will update my mobo and CPU or i may just buy another sound card that comes with win 7 64 bit drivers. I hate wasting time on problems like this as it appears there is no solution. I have tried heaps of creative drivers and none are working with this 64 bit system...Oh well
  10. Posts : 1,996
    Windows 7 Home Premium 64 bit
    Download the latest drivers from here.....
    Realtek
