no sound due to missing PCI input device
dman420
8:25 AM
like it says no sound due to missing PCI input device im so lost i reinstalled my audio drivers from dell website been googleing all night cant seem to find a solution all the sites i googled were dead ends thanks in advance for any help.
Windows 7 Ultimate x64CPU Type DualCore Intel Pentium D 820, 2800 M...Dual DDR2 SDRAMNVIDIA 8400 GS
Dell XPS 400
CPU Type DualCore Intel Pentium D 820, 2800 MHz (14 x 200)
Dell XPS 400 / Dimension 9150 Motherboard ID <DMI>
Dual DDR2 SDRAM
NVIDIA 8400 GS
sound blaster Audigy2 zs
hp pavilion mx704
samsung 500GB SATA
You have a sound card right?
Perhaps it isn't fully installed (plugged in). You may need to open your computer and securly attach it back to your motherboard.
Microsoft Windows 8.1 Pro 64-bitIntel(R) Core(TM) i3-4130 CPU @ 3.40GHz8.00 GBNone
Custom Asus Build
B85M-E
8.00 GB
None
Asus 23.6" Monitor
INTEL SSDSC2BW180A4
Samsung SSD 840 PRO Series
Seasonic S12II-380Bronze
Lian Li
Fan, Passive
Logitech K120
Microsoft Touch Mouse
Eset Endpoint
Internet Explorer, Chrome
Make & Model of PC?
MS Windows 7 Professional 64-bit SP1AMD FX(tm)-6100 Six-Core Processor Socket AM3...8.00 GB Dual-Channel DDR3 @ 802MHz (11-11-11-...NVIDIA GeForce GTX 560 Ti
Self Build
AMD FX(tm)-6100 Six-Core Processor Socket AM3+ (942)
ASUSTeK COMPUTER INC. SABERTOOTH 990FX (AM3r2)
8.00 GB Dual-Channel DDR3 @ 802MHz (11-11-11-36) 1.5Volts
Onboard Realtek HD
shimian (1920x1080@60Hz)
1920*1080
OCZ-AGIL ITY3 SATA Disk Device 120GB
Corsair TX 750
Corsair
WaterCooled
Microsoft Wired
Logitech USB Optical TiltWheel Mouse
Realtek PCIe GBE Family Controller 20MB*1MB
150GB Internal Hard Drive for Backing Up Important Files -
Hauppauge Nova-DT Dual DVB-T Tuner Device (+IR) -
USB PC Camera with Mic (SN9C105)
I found this as the dell site with the downloads, perhaps you already found it. It only lists vista 86x though. Perhaps some more looking will pull up other drivers Drivers & Downloads
Custom Asus Build
B85M-E
8.00 GB
None
Asus 23.6" Monitor
INTEL SSDSC2BW180A4
Lian Li
Fan, Passive
Logitech K120
Eset Endpoint
So this is your make & model (XPS/Dimension 400/9150) and your after a Windows7 64bit driver for your sound card?
Well i found a Vista 64bit one which should work with Windows 7 64bit!! I will give you the link. Please read the instruction first!!
Good Luck!!
Self Build
Onboard Realtek HD
1920*1080
Corsair TX 750
Corsair
WaterCooled
Microsoft Wired
Could there be a conflict between the onboard audio and the sound card (You have Sound Blaster Audigy2 zs sound card, I believe)? You may have to look for the sound card driver here: Creative Worldwide Support and then select windows 7 x64*, or try this (Same thing but I've already located the driver for you): http://support.creative.com/downloads/download.aspx?nDownloadId=11314 (If it says something about a server error, try reloading the page)
*ps don't download any beta drivers, stick to searching for just the drivers
Custom Asus Build
B85M-E
8.00 GB
None
Asus 23.6" Monitor
INTEL SSDSC2BW180A4
Lian Li
Fan, Passive
Logitech K120
Eset Endpoint
