No sound through left speaker
Page 1 of 3 123 LastLast
  1. Posts : 11
    Windows 7 Home Premium 64 bit
    Hey guys, just got my new laptop (Toshiba L650) with Windows 7 Home Premium 64bit, plugged in my external sound card (default 5.1 surround from Maplin) and updated to the windows 7 driver.
    I only have three speakers and the sub plugged in (front right, left and centre), which is the exact same configuration I had on XP and Linux Mint. For some reason there is no sound coming through my left speaker.
    Front right speaker plays correctly
    Front left and front centre sounds all come through the front centre speaker
    All cables plugged in and working properly.
    Help!
  2. Posts : 9,582
    Windows 8.1 Pro RTM x64
    Hi m1001879 and welcome to Windows 7 Forums
    Does the left speaker actually work? Try physically swapping it over with the right one (which you know works).
  3. Posts : 11
    Yeah, it works fine, I did this earlier and got no sound through the other speaker instead. It seems to be a problem with either the driver or windows 7.
  4. Posts : 1,870
    MS Windows 7 Professional 64-bit SP1
    Check the jack is all the way in, these things are tight when they are new.
  5. Posts : 11
    The speakers aren't new. The only thing that is new is the laptop. The USB connection to the sound card is fine as the other speakers are working, just not the left.
  6. Posts : 11,424
    Windows 7 Ultimate 64
    m1001879, Welcome to SF. These audio issues are most often related to the pin and connector not making a good contact. I would suggest you make and unmake this connection many times and also hit the hole with some air. Then use a small amount of surface enhancer like Caig Gold ! When making the connection rotate the plug and likely the contact will return also if the cable is under any tension it can be an issue as well, please make sure the cable drapes so no tension is on pin and plug.
  7. Posts : 1,870
    I see, Whats the make and model number of that USB sound card from Maplin.
    Link would be helpful.
  8. Posts : 11
    Thanks for the welcome! There's definitely no problem with any of the cables or connections. This exact same set up works fine when run through Linux (on my old laptop) with no physical adjustments at all. The issue is definitely software related.
  9. Posts : 11
  10. Posts : 11,424
    I would play with the left speakers lead while some music is playing. Grab it at the speaker and move and grasp it all the way back to the input/output. I suspect the wire could have a break in it !
