VIA HD AUDIO DECK sound distortion
Icewing726
8:49 PM
When my computer first turns on the sound in the speakers is distorted. Its very scratchy and if theres enough volume in them you can hear a hum. When I right click the icon on the tray for the hd audio deck and click exit the sound problems persist, but when I reselect the program I just closed it instantly corrects the distortion completely. What is going on and how do I fix it?
windows 7 Professionalamd phenom II x4 965 3.4Ghz Black edition8GB (2X4 Corsair)EVGA NVIDIA GEFORCE GTX 295 1.7Gb & GTS 250 1 GB
Cyberpower Pc
Asus M4A78T-E AM3 DDR3 790GX Crossfirex AMD
8GB (2X4 Corsair)
Onboard 7.1 Sound
Polaroid 22in
2TB SATA-II 3.0Gb/s 32MB Cache 7200 RPM
Corsair CMPSU-950TX Power Supply
Raidmax Sagitta II/Window/Silver
Case Fan 120MM & ASETEK 120MM Watercooler
No replys and still no help online please tell me how to fix this problem. If i play test sounds through the audiodeck it plays fine but any other program sounds scratchy. If i reset the audiodeck it works again for a little while any one know how to fix this.
Cyberpower Pc
8GB (2X4 Corsair)
Onboard 7.1 Sound
Polaroid 22in
