Microphone sound level?
Jepe
4:47 PM
Yeah, when I go to the sound settings and then to the microphone I see the Microphone level (that can be set from 0 to 100) and then the dB setting (0-30)
I'm using my laptops own mic and so I don't need to shout on it I put those both to the max, 100 and 30. But when I go back later during a call etc. I notice that the Microphone level has dropped back to like 20...
What does this? It's really annoying to contantly put the level back to 100 :/
Windows 7 Home Premium 64bitIntel Core i5-450M4GB DDR3-1333MhzATI Mobility Radeon HD5870
MSI GX740
Intel Core i5-450M
4GB DDR3-1333Mhz
That's because whatever program is that you're using (Skype, Windows Live Messenger, etc.) is adjusting your microphone levels automatically.
What you need to do is to look in the program you use for this purpose and check the audio/video configuration, disable the option that says "Automatically adjust my microphone levels" and that's it :)
Windows
Windows
Hi Jepe,
Right-click the speaker icon in the notification area and click on either Playback devices, Recording devices, or Sounds. Switch to the Communications tab.
You have probably got this set as above. This is the default, so you might want to try Reduce the volume of other sounds by 50% or Do nothing instead.
Dwarf Dwf/11/2012 r09/2013
Windows 8.1 Pro RTM x64
ASRock Z77 Extreme4-M
Iomega 1.5TB Ext USB 2.0
WD 2.0TB Ext USB 3.0
Gigabyte IF233
Avast! 8.0.1497
IE 11
