5.1 surround sound help
mustangman16
Bringer of Questions
Power User
12:11 AM
I've recently found out that my sound card application (creative audigy) is not compatable with win7 and have yet to find any creative programs that work with my computer. Is there a way around this to still be able to play music on 5.1 surround sound? Like a generic application to play music in 5.1? Or am i just being dumb?
Windows 7 Build 7229 x86Intel Core 2 Duo T7250 (2.0GHz/800Mhz FSB 2M ...4.00 GB DDR2, 667MHz 2 Dimm128MB NVIDIA GeForce 8400M G
Dell XPS M1530
Intel Core 2 Duo T7250 (2.0GHz/800Mhz FSB 2M L2 Cache)
SigmaTel High Definition Audio
15.4 inch Wide Screen WSXGA+ TrueLife; 31.5'" HDTV
1680 X 1050
200G 7200RPM SATA Hard Drive Free Fall Sensor
Logitech Cordless Desktop MX5500 Revolution Bluetooth
100 mbps
That should be "x86" not "x84" in your system specs just to let you know for the 32bit.
Which Creative model are you running? If you have one of the Audigy 4 models or any X-Fi series card no problem on the drivers and audio console launcher! I've been through the Creative support site for those enough times. You system specs show SigmaTEl for the sound card.
    W7 Ultimate x64/W10 Pro x64/W11 Pro Triple Bo...AMD Phenom II X4 975 Deneb 3.6ghz - 965 2nd r...Kingston Hyper X DDR3 1600 1.5v 16gb - Hyper ...MSI HD Radeon 5750 1gb - MSI HD Radeon 6450 o...
    Custom builds = 2
    Asus 1440x900 - HP 1600x900
    Zalman CNPS9900A
    W7 Pro x64/W11 ProAMD Deneb 3.6ghz - 965Kingston Hyper X Fury 8gbMSI HD Radeon 6450 DVI Output
    CUSTOM ASSEMBLY
    W7 Pro x64/W11 Pro
    1600x1080
    NZXT Vulcan mini tower
    DSL 5G
Sorry mistype lol. Anyway, Right now its a sigmatel high definition audio but it only supports 2.1 when i look into it. The screen shots show what my problem is. i used to use my creative audio center to play in 5.1 surround sound but i cant seem to open it. I've been through Dell and they told me its not compatable with win7 and creative hasnt given me any help either. I tried downloading all the beta drivers for like every audigy but they dont install because they arent compatable.
Dell XPS M1530
1680 X 1050
100 mbps
No problem! I've been doing some of that typo stuff lately!:o :D But since that was in your profile info I thought I would let you know about it.
The first problem right off since you are no longer running any Creative card is to remove all Creative software/drivers since the software part is likely the cause due to a clash with that for the SigmaTel card's own. You can't mix the softwares and drivers for two different brands without running into some type of problem.
You'll need to take a trip into the Programs+Features section in the control panel to see those uninstalled there. Also look in the device manager in the sound, video, and game controllers section for any Creative items left over.
    Custom builds = 2
    Zalman CNPS9900A
    CUSTOM ASSEMBLY
    W7 Pro x64/W11 Pro
    1600x1080
    DSL 5G
Pssst...HT Omega products are the future. I have the Claro plus, it has W7 x64 drivers....it's got the latest cmedia oxygen chip, it sounds FANTASTIC! I never, ever hear a snap, crackle or even a pop. Oh, DTS, no problems!
HT Omega - The Next Generation in Audio.
7600x64 RTMIntel® Q6700, 2.66 GHz stock clock (upgraded)4g (upgraded)Sapphire Radeon Toxic HD 3870 512MB GDDR4 (up...
Dell E520
7600x64 RTM
4g (upgraded)
Sapphire Radeon Toxic HD 3870 512MB GDDR4 (upgraded)
HT Omega Claro Plus (upgraded)
22' , 40"
1050, 1080p
1.5tb (upgraded)
Zalman 600w (upgraded)
stock Dell
dell
dell
100m Fiber optical
Bought the Dell secondhand for cheap and upgraded cpu, vga, ram, soundcard, psu and HDD's.
First of all you XPS M1530 never had a Creative sound card in it, so installing anything from Creative is a waste of time. What it has is the Sigamtel onboard audio, and what you are trying to get to work is the Audigy (or even possibly X-Fi) MB software. What this is is a software package that Dell and a few others bought/licensed from Creative so that the onboard sound can use some of the audigy or X-Fi software, it in no way means that you can install the Creative drivers or any of the software directly.
You have to have the updated MB package from Dell, and no Creative will not help you with this. Until Dell gets an updated version that works with Vista and/or Windows 7, you're stuck with just using the driver that is available from Dell,
Drivers & Downloads
Have a look on the dell forums and I'll bet you'll find quite a few people with the same problems. Time to start nagging on Dell to get it updated.
Going to look funny trying to jam one of those into his laptop.
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
If i used to use the SB audigy then is there another program i can use to play in 5.1 with the sigmatel audio hd?
Dell XPS M1530
1680 X 1050
100 mbps
Not that I can think off the top of my head. I can pretty much guarantee that there won't be any updates for it coming from Creative, that is unless enough people put enough pressure on Dell to get it updated. You could also get in touch with Dell and see if the version of the X-Fi MB they have is compatible with your card, and if so see about buying it from them (probably around $30.00 from what I have seen). If they do have it and it is compatible then you need to ask them when they plan on having a version that works with Windows 7,
X-Fi MB & Win 7 - DELL COMMUNITY
Have you checked in the Windows playback options (I assume there is zero software support that gets installed with the Sigmatel drivers), and see if there is an option for speaker fill (if there is it will be under the Enhancements tab, if the tab is even there)? Also make sure that you have it set to 5.1 in the Windows settings.
Another thing you can try after checking the above settings is if you don't have it, get Winamp (free version will do),
Winamp Media Player - MP3, Multimedia, and Music Player
and use this plugin,
VL Sound for Vista v1.0.0.5 - Customize Winamp Media Player
It works very well at playing stereo sources (all mp3's) in 5.1.
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
Ya but can you replace a laptops sound card?
Dell XPS M1530
1680 X 1050
100 mbps
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
Windows 7 64bit RC2AMD Athlon 64 x2 5200+4GB Corsair XMS2 DDR2 800XFX 8600GT
Windows 7 64bit RC2
Asus M2N E SLI
XFX 8600GT
Creative X-fi Titanium
WDC Blue 750GB
WDC Black 1TB
Corsair VX 5500
Akasa Zen V2
Zaim welcome to the forums.
Guess you missed the sixth post in this thread where I wrote,
Unfortunately your suggestion just won't work.
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
ah lol didnt see that. thanks for pointing that out
Windows 7 64bit RC2
Asus M2N E SLI
XFX 8600GT
WDC Blue 750GB
WDC Black 1TB
Corsair VX 5500
Akasa Zen V2
Mine looks like an express card. It looks like there are screws right under my express card so i could investigate into taking it out and replacing it. Thanks a lot storm! Do you have any suggestions on an express card with 3 holes instead of the one you linked with only 2?
Dell XPS M1530
1680 X 1050
100 mbps
Unfortunately that is the only one I know of, that and laptops aren't really my strong suit. Hopefully someone else on here will have a recommendation for you. Meanwhile while waiting it might be worth having a look around over here,
Notebook Forums and Laptop Discussion - Powered by vBulletin
and see what others are using and/or recommend.
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
Ya i've been looking things up and since i plan on buying a new computer when win7 comes out i might buy the usb one for convienance and its cheaper. Thanks a lot for all the help stormy. +1
-stang
Dell XPS M1530
1680 X 1050
100 mbps
5.1 sound problems
Hi,I have a C-Media cm6501 sound card in my Asus M2N-E SLI motherboard and I have installed Windows 7 Ultimate (x86),I managed to configure everything to get the 5.1 system working,but the player,with or without codecs,does not play in 5.1,it just uses the two front speakers.I tested the speakers in the driver program and in windows in control panel,sound and it works fine but it stops there.I tried Winamp,Media player 11,Media player classic and 3 types of codecs and it's the same result,what can I do to make my 5.1 surround system work? I had Windows Media center edition(SP2) before and it worked fine.I also tried vista and I had the same problems I'm having with Windows 7.
