Windows 7: Extremely low sound from earphones...Help!
13 Feb 2011   #1
Konoshur
Windows 7 Ultimate 32bit
I have a XFX nForce 680i LT SLI board with onboard Hi-Def. Using Win7 Ultimate 32bit.
I use my Blackberry earphones plugged into the back panel green jack.
Never had any problems with this setup until about a week back.
A week ago, without ANY apparent reason (no new programs/drivers installed), the earphones stop working.
In 'playback devices', it started showing 'Realtek Digital Audio' as the default playback device and 'Speakers' were grayed out and annotated 'not plugged in' even when I plugged in my earphones.
Since then, I have done the following-
1.System restored to a time when the audio was fine.
2.Updated to latest drivers from Realtek.
3.Rolled back, updated to driver version recommended by XFX (not the latest, but still later than my original drivers)
4.Updated my motherboard drivers.
All this to no avail and I was beginning to think that I had some bad hardware...
but then I did manage to partially solve my problem via a software adjustment I read about here...
The Realtek update installed a new version of the HD Audio Manager, where I was able to 'disable front panel jack detection', which resulted in the speakers suddenly becoming enabled.
Sound is now back in my earphones...however- the volume is very, very low.
More searching on this issue led to a lot of stuff about 'needing external amplifiers' and 'onboard audio giving only line- level output'...I dont think that's it, though, as the earphones have worked fine with the same hardware for years now.
The earphones themselves are fine- work great with my laptop and the Blackberry itself. Also, I have made sure all sliders are turned up everywhere and nothing is muted.
Any help is appreciated.
13 Feb 2011   #2
Maguscreed
Windows 7 x64
The first thing that comes to mind is that the actual audio jack on your computer has gone bad. Are you plugging into the front audio jack on your case, or directly into the audio device in the back of the computer? ...and have you tried both plugs?
13 Feb 2011   #3
Konoshur
Quote   Quote: Originally Posted by Maguscreed View Post
Thanks for your input.
I'm plugging into the rear panel at the back of the case. When I try the front panel, even the low volume sound disappears.
If it was a hardware issue, would the HD Audio Manager tweak have had the effect that it did?
If it is a hardware issue with the jack, I read somewhere that we can reassign the line-out to a different jack....can we?
13 Feb 2011   #4
Maguscreed
Windows 7 x64
I also have a 680 chipset board, and the front audio has also given me trouble because it wants to assign a different output method to it. Of course it could be that your front panel audio is just not hooked up/wired correctly too. I see that a lot in custom built machines. If you still have the manual that came with your motherboard you should be able to check that though.
If we could get the front panel working we could eliminate the jack as the source of the issue.
13 Feb 2011   #5
Konoshur
OK...went in and got my hands dirty.
True enough, front panel is not connected to the board....apparently in my cheap-ass cabinet, the front audio jack has no connectors leading from it that can be plugged in! So there's no way of finding out...
Anyway... any other stuff I can try?
15 Feb 2011   #6
Konoshur
Bump for Hope!!!
Headphones plugged to speakers,extremely low sound.
I have plugged the headphones to my speakers but the sound is extremely low. I have tried different headphones it is the same low sound. These headphones in other devices work perfect. The speakers also work perfect.What is the problem?Any suggestions? I have a desktop Microsoft Windows 7...
No Sound Boost Bar Extremely Low Mic Sound
I have no boost bar in the mic settings. I have no idea why. The worst part is that Windows 7 is making my mic ultra quiet. Its pretty much in my mouth. How do I fix it? The Mic works great on my Mac and consoles but on my Windows 7 PC the mic volume is ultra low.
Sound jumping from normal volume, to extremely low.
So for the past few days, whilst watching youtube or playing a video game, I have noticed that my computer's sound has bounced from normal volume to extremely low. Nothing seems to effect it, as it does it randomly. I have changed out wires, and speakers (I only have my center speaker hooked up...
sound is low when listening on my earphones
Hi there I have noticed recently that when I use my earphones which Ii plug directly into my speakers, if I watch a movie the music is very high but voices very low and I have to turn the volume up full to even hear them. This happens on VLC and WMP but if I watch something using a web browser,...
Sound only coming out of one earphone, not the earphones.
Hi all,for So I have been having a fair amount of problems with my speakers since I acquired the laptop in October; the quality and volume are both terrible, but after reinstalling drivers and speaking to members on this board, and we deduced that the laptop speakers were just shocking. ...
Audio too loud on earphones
I upgraded to windows 7 but every time I use my earphones I need to keep my volume at level 1. If I go even higher then level 10 the audio is really loud. I'm using Realtek HD.
