Realtek high definition - bad sound quality
  1. Posts : 2
    Windows 7 Home Premium 65bit
    I just bought a Gateway laptop (Win 7 64-bits) with a Realtek high definition. I listen a lot to classical music and I am disappointed with the sound quality of the card.
    I listen the music with a good Seinheiser headphone. The problem is not the headphone because I switched back and forth between the new laptop and a 6-years old Compaq desktop and the desktop sounds much better. On both computers, I have the equalizers set as flat and no audio effects.
    The problem on the laptop is that the sound sounds "muffed", with no treble and no color. I checked the drivers and they are the latest.
    I am pretty sure that this is a good quality card and the sound should be good. What should I try?
    Thanks,
    Tom
  2. Posts : 12,012
    Have you fiddled with the settings in the Realtek HD audio control panel, as shown below?
    I'd turn off any special effects or enhancements to begin with.
    I just began using Realtek myself, but have not done any critical listening yet to decide if I like it or not.
    Attached Thumbnails Attached Thumbnails Realtek high definition - bad sound quality-untitled-1.jpg
  3. Posts : 2
    Yes. As I mentioned on my email, equalizer is flat and no special effect.
