Audio stops working when using microphone!
CosminWTF
1:09 PM
Hello guys !
I have a problem for 2 years , my audio stops working when i plugin and use the microphone , it's really annoying me , when i play games , when i talk on skype , etc.. it just randomly stops after an amount of time! My motherboard is Intel DP55WB and i use Realtek audio drivers. I tried many stuff to fix it but it's no use, nothing works.
Please , I really need your help.
Windows 7 Ultimate x32
What happens if you use the Rear mic connection instead of the front panel mic connection? If you haven't tried this, do it as there may be some type of connection problem either in the motherboard audio connector or the cabling or connector on the front panel of the case. Also, disconnect the front panel audio cable (unplug it from the motherboard) and then use the rear Mic jack and see if it makes a difference.
I have an Intel DP35DP motherboard and had a problem with the front panel audio on the PC I built and it turned out to be a problem with the front panel headphone/mic I/O board in my case.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
I use only the rear mic connection because i don't have the front panel mic connection on my carcass.
EDIT : I'll try to see if there are some problems in the cabling.
try this:
control panel >> hardware and sound >> sound >> communications tab >> set to 'do nothing'
is yours set this way already?
ultimate 64 sp1i5 2500K [email protected]8 gigs GSkill Ripjaws 1600amd hd6950
mickey megabyte 1234
ultimate 64 sp1
MSI P67A-GD53
amd hd6950
creative x-fi gamer
samsung 24"
antec 550
antec three hundred
i'm a cooling fan
saitek eclipse ii
logitech g3
about 4 Mbps
i love win7
@mickey megabyte : I tried that , but it still doesn't work.
Bump!
bump
win 7 x64
win 7 x64
I have the same exact problem when i plug my new Razer Kraken Pro(world of tanks addition)AUX and MIC jack in my front panel it works fine if i watch videos browse youtube
But once I play dota 2 after 10 min the sound complete cuts out and pulled off my headphone from front panel jack my speakers does not produce a sound but only the speaker bar it shows sound is produce everytime is clicked.
Then all my videos or music becomes jerky and does not play sound and only way to fix it is to restart it my PC
I thought it was realtek audio driver issue so uninstalled it and try to run the game again the cut out still happens. bought a new graphics R9 280 to replace HD5770 the old one, because I thought it could be the cause of jerky motion in the video player, but it the cut out still happens . disabled the AMD HD audio in device managers still same isssue. disabled all other device in sound still happens.
I'm out of ideas of what to do besides having to
Operating system
Windows 7 64bit
My PC specs are
i5 750 2.6Ghz
DP55WB motherboard
R9 280 sapphire graphics
12GB DDR3 Ram
CoolerMaster RC-K350-KWN1 K350 USB3.0 Gaming case
case has USB 3.0 for one of the front panel and i bought and adaptor off ebay to convert USB3 plug to USB 2.0 and plug into Mobo extra note if that really does influence it.. but i high doubt
Accessories
Gigabyte Kforce keyboard
Razer Deathadder
Razer Kraken (Headphones) AUX jack and Mic Jack (NOT USB)
Speaker Logitech X-530
Tempted for a reformat of windows 7.. but dont know if that would solve the issue
Western Australiai5 750 2.6 Ghz12GB DDR3R9 280 Saphhire
Western Australia
i5 750 2.6 Ghz
DP55WB
12GB DDR3
R9 280 Saphhire
1TB SATA 3.5"
AVG
chrome
