win 12 can not rip
Page 1 of 4 123 ... LastLast
  1. Posts : 13
    win 7
    win 12 can not rip
    I am running win 7 wmp 12. I can not rip. The rip area under tools, rip, change location is not grayed out but there is nothing there. If I try to rip, I get an error message, that some songs can not be ripped. Please help.
    I have reviewed most of your posts, man there is a lot but found no answer.
    I was running xp, did a clean install. I have not been able to rip since day one.
  2. Posts : 2,292
    Hmmm, could you please post a screenshot, I am not exactly sure what you meant. Also, please include the rip tab in the options window.
  3. Posts : 13
    win 7
    win 7 wmp 12 can not rip
    Is this the screen shot you need?
    win 12 can not rip Attached Files
  4. Posts : 17,322
    Win 10 Pro x64
    You may want to try this method for posting screenshots,
    https://www.sevenforums.com/tutorials...en-forums.html
  5. Posts : 13
    win 7
    Sorry. I am a super novice. I will try again. see attached
    Attached Thumbnails Attached Thumbnails win 12 can not rip-2.jpg   win 12 can not rip-untitled.jpg
  6. Posts : 17,322
    Win 10 Pro x64
    Here you go lvpeat, I just tried to rip a cd and got the same issue. then I found this solution from microsoft, it just doesn't know where to put it. just follow the steps in the answer to direct it to a location. mine started ripping just fine once it knew where to put it. And don't worry about the novice thing, EVERYBODY is at one point.
    Attached Thumbnails Attached Thumbnails win 12 can not rip-wmp-answer.png   win 12 can not rip-wmp-answer-2.png
  7. Posts : 13
    win 7
    I tried that before. On mine there is no location to change. It is blank. Not grayed out but blank.
  8. Posts : 2,685
    Windows 7 Ultimate x86-64
    Is this a normal Audio CD? Have you tried Exact Audio Copy:
    Introduction Exact Audio Copy
  9. Posts : 17,322
    Win 10 Pro x64
    So was mine, you need to tell it where to put your music. if you click on the add button ( in the second screenshot ) you can pick a location, like "My Music" which is where I put mine.
    Attached Thumbnails Attached Thumbnails win 12 can not rip-untitled.jpg   win 12 can not rip-wmp-answer-3.png
  10. Posts : 13
    win 7
    win 12 can not rip
    To Frostmourne - I have tried several different audio disks withe same result. I want mwmp to work. Why use two different audio products? If I delete wmp, it could effect other parts of windows.
    To Derekimo - good suggestions but I have tried the above but the music library,as in your second pic, does not appear.
