Sound Wave - Reducing help!
lazalaza
3:53 PM
Hi. On windows xp, I used to reduce Waving when the sound was bad (headphones) and when it was like "zzzzzz" on loud parts (hope you understand me).
Here, the second one:
I would like to reduce that waving on Windows 7... I can't listen to music because of it, it just irritates me (basses especially!)! Please help me!
No one!!!!!!!????
I'm not sure what you're asking.
If you'd like to reduce the volume levels, that can be done by accessing the volume mixer.
What sound card or on board audio are you using?
Windows 7 Home Premium 64 bitIntel Core i7-4790G.SKILL 8GB (2 x 4GB) DDR3 F3-10666CL9D-8GBNTAMD Radeon R7 250
Intel Core i7-4790
GA-Z87X-D3H
AMD Radeon R7 250
Realtek ALC892
1920 x 1080, 1280 x 1024
WD5003AZEX
WD10EZEX
Samsung HD103SJ
Samsung 128 GB 840 PRO
SeaSonic M12II SS-500GM
Fractal Design Define R4
Zalman CNPS9900ALED
Logitech K800
Logitech M705
16 Mbps
No, I want to reduce what was called "Wave" on XP...
Idk what card I am using :/ How can I know that?
There's no longer a wave mixer.
Right click on your volume mixer in the bottom right corner.
Open Volume Mixer. Sounds that are available can be adjusted there.
To see what kind of audio device you have installed, go to Start> Search>
type "device" and select "Device Manager".
Open Sound, video and game controllers.
Intel Core i7-4790
GA-Z87X-D3H
AMD Radeon R7 250
Realtek ALC892
WD5003AZEX
WD10EZEX
Samsung HD103SJ
Zalman CNPS9900ALED
Logitech K800
Logitech M705
16 Mbps
Thank you, but there's only the main volume mixer. I mean the main volume, like it was on "one click" on XP. I would like to reduce waving, but thanks for telling me it doesn't exist here so I can stop searching it :sight: :/
What is "waving"??
Dell S2340M 23 inch IPS
1600 x 900
Antec Solo II
Microsoft 200 6JH-00001 USB
Pale Moon
He's referring to the wave volume control, as seen in the first post. Both Vista and Windows 7 differ from earlier incantations of Windows (e.g. XP) when it comes to volume level controls. We still have a master volume/mute control to control the overall level, but now each source has its own level control, even if they are of the same type.
Dwarf Dwf/11/2012 r09/2013
Windows 8.1 Pro RTM x64
ASRock Z77 Extreme4-M
Iomega 1.5TB Ext USB 2.0
WD 2.0TB Ext USB 3.0
Gigabyte IF233
Avast! 8.0.1497
IE 11
