Windows 7: Front Jack problem
27 Feb 2011   #1
aman113
Windows 7 64bit
Front Jack problem
Hi guys I seem to have a weired problem, I recently swaped my current case with an old case i had which is lot bigger. The problem is that the front audio jacks don;t get detected when the headset is pluged in however when i plug the headset in half way then the jack gets detected it and I can play music watever but very bad quality and once I push it all the way in It stops detecting so I duno what is the problem so any help will be appreciated.
27 Feb 2011   #2
The Howling Wolves
aman113,
Welcome to 7 forums!
1. Test your headset on someone else's computer to see if your headset is working properly.
2. See if friend has a headset to test your new case.
Also check to see if you have all updated driver's on your system.
Could be as simple as headset cable is going bad. IMHO
Post back so we can all learn.
27 Feb 2011   #3
Dwarf
Windows 8.1 Pro RTM x64
Check also that you have connected the cable up correctly to the motherboard header and that the correct mode is set in the BIOS for an HD or AC'97 front panel (if available).
27 Feb 2011   #4
aman113
Windows 7 64bit
Hi thx for your replies I really appreciate it, Firstly the drivers are up to date and I have tried different headsets and none of them work however they all work in the rear jacks. In addition I have made sure that everything is connected correctly inside the case. I went in the BIOS but I can't find anything related to HD or sound or AC'97 but my question is why the headset gets detected when its plugged in half way.
27 Feb 2011   #5
aman113
Windows 7 64bit
Ok i have now tried the the jacks from my other case and they are working correctly so I think something is wrong with the jacks in this case or may be its not supported as this case is very very old probably about 4 and half years old, anyway thx for your support and I will just use the rear jacks in meantime.
27 Feb 2011   #6
The Howling Wolves
Read through this link as other had problems with front jacks not working.
Various solutions so check it out as you may have an incorrect setting.
Front jack not working for Realtek HD Audio on Windows 7
 Front Jack problem
How do i output sound through the back panel jack and the front jack
Hey guys! I want to output sound both through the headphone jack on the front of my case and the sound jack at the back of the computer, how would i do this? I looked around in the sound setttings and the realtek audo and couldn't find anything.
front jack not working
hi, my computes operating system is split into 3, one being windows xp, vista and windows 7...windws 7 being the one i use the most. Im having problems with front jack cuz when i connect headphones or speakers it doesnt work..my rear jack works...but the kick is dat the front and rear jack works...
No sound - Windows only showing front jack and not rear jack
Hi everyone, I recently reinstalled Windows 7 pro on my PC. Sound was working fine before. Now Windows only shows a front jack in the sound playback device settings. There is no front jack, however, only a rear jack and it is not working. If I play music the levels monitor shows sound playing,...
Front Jack Error
I just Installed Win7 Ultimate 32-bit. have Installed all driver for my comp and Realtek HD of course. but the front jack is not working!!!!! when i used XP it's still working but when i change it to Win7 it's not working!!!! i have downloaded the latest Realtek HD but not change anything...anybody...
Headphones Problem - Front Jack
I have tried everything to enable headphones (update driver, instal different audio managers, etc.), but still my front jack plugged-in headphones are not detected. Please HELP
Front Headphone jack..
Hi guys i m new here... need some help. My front headphone jack is not working but mic is working.. Headphone works properly at rear jack. System info. System model - PI945GCM Processor Intel(R) Core(TM)2 Duo CPU E7300 @ 2.66GHz, 2670 Mhz, 2 Core(s), 2 Logical Processor(s)...
