Windows 7: Help fixing hd audio device on ultimate please -have tried other fixes
01 Mar 2011   #11
Windows 7 Home Premium 64 bit
Now that the file checker has supposedly fixed things, try doing a hardware scan from the device manager. Hopefully it will load the drivers.
01 Mar 2011   #12
Windows 7 Ultimate x86
still no luck my friend!
What I have done is the file checker, then I have scanned for new hardware again with no results other than the code 19 still.
Should I try uninstalling realtek from here and then reinstalling it manually? I also have another entry now so there is "High Definition Audio Device" and "Realtek high definition audio"
Like is there a specific routine I should follow after this file checker thingy?
01 Mar 2011   #13
Download and install the Nvidia video driver which will include High Definition Audio Device driver.
Drivers - Download NVIDIA Drivers.
Yes, uninstall the Realtek driver and install it manually.
Search this Thread:
Advanced Search
HDMI Audio Device No Longer Appears as Playback Device
I was wondering if you could give me some advice on a current computer issue. So, I've got my TV hooked up to my PC as an extra monitor via HDMI. Up until last night I was able to get audio from my PC to be played/heard/whatever through the TV. Earlier in the evening, I saw a bunch of...
not plugegd in onboard audio device after disconnecting external audio
I have an Echo Audiofire4 firewire device, for some reasons I need to constantly switch between Echo and my onboard audio device (realtech sth). I remember I could do it in the past, but due to the Echo installation problems I disabled it from windows startup menu and now, though I enabled it...
restart problem BSOD glitchy audio win7 ultimate w/ m audio 1010lt sou
m audio 1010lt sound card not sure why..usually when I shut down it restarts automatically..recently i was watching a movie and it restarted out of no where..any help appreciated.... windows ultimate 7 amd 6000 3.0 ghz processor 4 gb ram I did do some searching i do have m audio 1010lt and...
BSOD Help and Support
Audio Playback (Default Device Realtek) Knocks Out SRS Audio Sandbox
Hi, I finally upgraded from Windows XP to Windows 7 and almost went back shortly after finding out I could no longer organize or manually arrange my own personal files and/or folders but luckily I discovered an application called 'Folder Options X' which has re-enabled that feature for me so I'm...
C-Media AC97 Audio Device. This device cannot start.
C-Media AC97 Audio Device. This device cannot start. (Code 10). Sound hardware on ASUS Mobo will not work after installing Windows 7. Latest drivers installed. Don't know what else to try?
need help fixing this "unknown device" pictures added
Hello everyone. Please assist me in fixing this issue. I have already installed and ran DriverMax. That did not help. Would appreciate any input, thanks.
