Windows 7: Help fixing hd audio device on ultimate please -have tried other fixes
28 Feb 2011   #1
joshuamaunder
Windows 7 Ultimate x86
I know a lot of people seem to ask the same question but I cannot solve this at all by trying any methods I have tried online so I decided I needed some help more personally!
I'm on windows 7 ultimate x86.
I was recently working on a music recording program when all of a sudden my speakers emitted an odd 'whine' and then my computer seized up completely. I then had to restarted it and when it came back on i received no audio what-so ever.
I have "no audio output device is installed" in the bottom right where the audio icon normally is and when I click troubleshoot it tells me that it is something to do with my High Definition Audio Device driver/s. I let it try and update them but it always says it failed to install.
Also in the device manager under Sound, video and game controllers all 7 entries have an exclamation mark including the realtek HD audio and the other 6 microsoft ones. When i right click and go to properties it says
"Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged.
(Code 19)"
I have tried disabling then enabling, installing and reinstalling the drivers from the realtek website and just uninstalling the drivers from the Device manager but to no avail and I am really stumped as to what has happened and how I can fix it.
All help would be appreciated!
oh and I can run Everest to give you a system over view if that would help? Just aslong as you say which bit you'll need
Thanks in advance
28 Feb 2011   #2
joshuamaunder
Quote   Quote: Originally Posted by p5bdkw View Post
Try re-installing the Audio driver from here....
Realtek
done that already but to no avail, just says the same thing as before even after multiple tries :/
Tis' a pain cause it was working fine before
28 Feb 2011   #3
Sardonicus
Windows 7 Home Premium 64 bit
Try a system restore to the point before you installed the music recording program.
28 Feb 2011   #4
joshuamaunder
I wish I had the opportunity to do so... sadly I have no restore points, I think stupidly they were disabled a while back
Any other ideas other than reinstalling the drivers? I can't windows update thingy wither because it always says device driver failed to install"
28 Feb 2011   #5
Sardonicus
Please post a snippet of your device manager with the questionable items.
28 Feb 2011   #6
joshuamaunder
Help fixing hd audio device on ultimate please -have tried other fixes-screeny.jpg
Hope that works okay and it has the right parts
28 Feb 2011   #7
Sardonicus
Restart the computer in Safe Mode, and then select Last Known Good Configuration.
This rolls back to the most recent successful registry configuration.
Start your computer in safe mode
01 Mar 2011   #8
joshuamaunder
gaaaaah this is immpossible it would seem, thanks for your help so far though.
Sadly again, no luck, it is still stating that 'no audio output device is installed' over the volume icon and still no-play in the device manager, it's having none of it :S
sorry 'bout all this but I do appreciate the help
01 Mar 2011   #9
Sardonicus
01 Mar 2011   #10
joshuamaunder
No luck again sadly... it said that there were errors, and that it fixed them then I retried to double check and it said no more problems, restarted and still have regestry/driver problems.
it is looking like I'll have to buy a new soundcard and if that doesn't work I'll have to do a full reinstall of windows 7 which I am really hoping is not the case!
Any last possible ideas before I give up completely? :S haha
HDMI Audio Device No Longer Appears as Playback Device
I was wondering if you could give me some advice on a current computer issue. So, I've got my TV hooked up to my PC as an extra monitor via HDMI. Up until last night I was able to get audio from my PC to be played/heard/whatever through the TV. Earlier in the evening, I saw a bunch of...
not plugegd in onboard audio device after disconnecting external audio
I have an Echo Audiofire4 firewire device, for some reasons I need to constantly switch between Echo and my onboard audio device (realtech sth). I remember I could do it in the past, but due to the Echo installation problems I disabled it from windows startup menu and now, though I enabled it...
restart problem BSOD glitchy audio win7 ultimate w/ m audio 1010lt sou
m audio 1010lt sound card not sure why..usually when I shut down it restarts automatically..recently i was watching a movie and it restarted out of no where..any help appreciated.... windows ultimate 7 amd 6000 3.0 ghz processor 4 gb ram I did do some searching i do have m audio 1010lt and...
BSOD Help and Support
Audio Playback (Default Device Realtek) Knocks Out SRS Audio Sandbox
Hi, I finally upgraded from Windows XP to Windows 7 and almost went back shortly after finding out I could no longer organize or manually arrange my own personal files and/or folders but luckily I discovered an application called 'Folder Options X' which has re-enabled that feature for me so I'm...
C-Media AC97 Audio Device. This device cannot start.
C-Media AC97 Audio Device. This device cannot start. (Code 10). Sound hardware on ASUS Mobo will not work after installing Windows 7. Latest drivers installed. Don't know what else to try?
Drivers
need help fixing this "unknown device" pictures added
Hello everyone. Please assist me in fixing this issue. I have already installed and ran DriverMax. That did not help. Would appreciate any input, thanks.
Drivers
