Windows 7: Sound on my comp doesn't work - pls help
01 Mar 2011   #1
Windows 7 Ultimate 32bit
Hello,
I see that this is a common problem and I have read many posts on this issue, but still have no solution.
I installed Windows 7 and now there is no sound. Before that I had WinXP. I tried to update the driver through the device manager but it says that it is up to date.
Processor is Pentium Dual Core E5200, Motherboard Asus P5KPL-AM.
Does anyone have any ideas? Pls help!
Thank you!
01 Mar 2011   #2
Win7 H.Prem. 32bit+SP1
Hi Time, no pun intended, if you click on the small triangle on the task bar, then customise, you'll get this:-
Hope this help.
01 Mar 2011   #3
Yes, that's correct. How is this helping me?
There is no sound at all.
01 Mar 2011   #4
Seemingly its not, I take it all your sound cables are connected properly and your speakers are not 'muted'. Then again you could be deaf!!! Name:  AngelPray.gif
01 Mar 2011   #5
That's very funny, thx.
I would appreciate some help on this matter.
01 Mar 2011   #6
Windows 7 Home Premium 64 bit
Selecting the Windows 7 Volume Mixer, Playback devices, what output device is checked?
01 Mar 2011   #7
64-Bit W7 Ult_sp1
Quote   Quote: Originally Posted by Time View Post
hiya Time..
are you using the motherboard's onboard sound..?
02 Mar 2011   #8
Quote   Quote: Originally Posted by p5bdkw View Post
Speakers.
Quote   Quote: Originally Posted by BugMeister View Post
hiya Time..
Hi, yes.
03 Mar 2011   #9
64-Bit W7 Ult_sp1
there should be a sound manager somewhere..
where you can set and test the speaker arrangement
this is the Realtek one:
you should have something similar..
- do a search on your system, it may point you in the right direction..
03 Mar 2011   #10
Check your BIOS and make sure that the Audio Controller [Azalia] is not set to All Disabled or Disabled.
Set the HD Audio mode to HD Audio.
and / or
Try Re-installing your drivers.
Realtek
Similar help and support threads for2: Sound on my comp doesn't work - pls help
My sound doesn't work? Sound & Audio
Solved Sound Doesn't Work After Ended Process of Audiodg.exe General Discussion
Hard drive from one comp work in another comp like it did before? General Discussion
Sound Occasionally Doesn't Work (Win7x64Ultimate) Sound & Audio
Sound doesn't work in Windows 7 Sound & Audio
My Comp doesn't always stay asleep... Performance & Maintenance
Sound doesn't work Sound & Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
