Sound on my comp doesn't work - pls help
  1. Posts : 5
    Windows 7 Ultimate 32bit
    Hello,
    I see that this is a common problem and I have read many posts on this issue, but still have no solution.
    I installed Windows 7 and now there is no sound. Before that I had WinXP. I tried to update the driver through the device manager but it says that it is up to date.
    Processor is Pentium Dual Core E5200, Motherboard Asus P5KPL-AM.
    Does anyone have any ideas? Pls help!
    Thank you!
  2. Posts : 2,362
    Win7 H.Prem. 32bit+SP1
    Hi Time, no pun intended, if you click on the small triangle on the task bar, then customise, you'll get this:-
    Hope this help.
  3. Posts : 5
    Yes, that's correct. How is this helping me?
    There is no sound at all.
  4. Posts : 2,362
    Seemingly its not, I take it all your sound cables are connected properly and your speakers are not 'muted'. Then again you could be deaf!!! Sound on my comp doesn't work - pls help-angelpray.gif
  5. Posts : 5
    That's very funny, thx.
    I would appreciate some help on this matter.
  6. Posts : 1,996
    Windows 7 Home Premium 64 bit
    Selecting the Windows 7 Volume Mixer, Playback devices, what output device is checked?
  7. Posts : 3,822
    hiya Time..
    are you using the motherboard's onboard sound..?
  8. Posts : 5
    Speakers.
    hiya Time..
    Hi, yes.
  9. Posts : 3,822
    there should be a sound manager somewhere..
    where you can set and test the speaker arrangement
    this is the Realtek one:
    you should have something similar..
    - do a search on your system, it may point you in the right direction..
  10. Posts : 1,996
    Check your BIOS and make sure that the Audio Controller [Azalia] is not set to All Disabled or Disabled.
    Set the HD Audio mode to HD Audio.
    and / or
    Try Re-installing your drivers.
    Realtek
