Sound on my comp doesn't work - pls help
Time
9:29 PM
Hello,
I see that this is a common problem and I have read many posts on this issue, but still have no solution.
I installed Windows 7 and now there is no sound. Before that I had WinXP. I tried to update the driver through the device manager but it says that it is up to date.
Processor is Pentium Dual Core E5200, Motherboard Asus P5KPL-AM.
Does anyone have any ideas? Pls help! :confused:
Thank you!
Windows 7 Ultimate 32bitIntel Pentium E5200 @2.50GHz
ASUS P5KPL-AM (Socket 775)
VIA High Definition Audio
Hi Time, no pun intended, if you click on the small triangle on the task bar, then customise, you'll get this:-
Hope this help.
Win7 H.Prem. 32bit+SP1
Look in my Signature.
Yes, that's correct. How is this helping me? :(
There is no sound at all.
Seemingly its not, I take it all your sound cables are connected properly and your speakers are not 'muted'. Then again you could be deaf!!! AngelPray.gif
That's very funny, thx. :sarc:
I would appreciate some help on this matter.
Selecting the Windows 7 Volume Mixer, Playback devices, what output device is checked?
Windows 7 Home Premium 64 bitIntel Core i7-4790G.SKILL 8GB (2 x 4GB) DDR3 F3-10666CL9D-8GBNTAMD Radeon R7 250
Intel Core i7-4790
GA-Z87X-D3H
AMD Radeon R7 250
Realtek ALC892
1920 x 1080, 1280 x 1024
WD5003AZEX
WD10EZEX
Samsung HD103SJ
Samsung 128 GB 840 PRO
SeaSonic M12II SS-500GM
Fractal Design Define R4
Zalman CNPS9900ALED
Logitech K800
Logitech M705
16 Mbps
hiya Time..
are you using the motherboard's onboard sound..?
Windows10 Pro - 64Bit vs.10547i7-965 Extreme Edition (8 Cores) at 3.3GHz (n...12G Corsair Dominator DDR3 - tripled2xAMD SapphireNITRO R9 380(4G) crossfire
benchtec, built to personal specs
i7-965 Extreme Edition (8 Cores) at 3.3GHz (no OC)
BloodRageX58 (Socket1366)
Sonar(SB)X-Fi onboard
SyncMaster P2050 20"
1600x900 (widescreen)
480G\OCZSolid3SSD, 64G\OCZVertex3SSD,60G\OCZVertex2SSD, 1TB\spinpointF1SATAHDD
1200w Power Station Gold
ANTEC 900/2 all blue lights, etc..
Noctua SE1366 NH-U12P - a tight fit, but a monster cooler!!
Logitech G19 (wired)
Logitech G9 Laser (wired)
150mb unlimited
IE11(RP)
Xbox One, Nokia735 Windows10 mobile, LG HD/DVD/Blu-Ray r/w, CyberlinkPowerDVD15, LogitechZ5500-SS(5.1), LogitechG35Phones-SS(7.1),MSOffice 2007,CorelDrawX7,Painter2016, Wacom Intuos Pro-SE
there should be a sound manager somewhere..
where you can set and test the speaker arrangement
this is the Realtek one:
you should have something similar..
- do a search on your system, it may point you in the right direction..
150mb unlimited
IE11(RP)
Check your BIOS and make sure that the Audio Controller [Azalia] is not set to All Disabled or Disabled.
Set the HD Audio mode to HD Audio.
and / or
Try Re-installing your drivers.
Realtek
Intel Core i7-4790
GA-Z87X-D3H
AMD Radeon R7 250
Realtek ALC892
WD5003AZEX
WD10EZEX
Samsung HD103SJ
Zalman CNPS9900ALED
Logitech K800
Logitech M705
16 Mbps
Thank you so much for your effort :)
I tried a lot of things and I'm not sure which one did a trick, I think after installing drivers from ASUS support site. Now it's working! ;)
Thank you again!
