5.1 Two Rear Speakers Not Working
hiranya
6:31 AM
Please help me with my problem. My PC configuration looks like this.
Mobo : Intel DX58SO
CPU : Intel i7 950
OS : Windows Vista Ultimate (32 Bit)
Sound : Realtek High Definition Audio
I have a 5.1 Creative LX520 Speaker, I have set the sound output to 5.1 in control panel, but when I test the speakers the two rear speakers does not work. But if I change the setting to 7.1 it works, but the sound from the rear speakers are like distorted. Please help.:(
Windows 7 Ultimate 32 Biti7 9502 GB DDR3 1300ATI 3450
Intel
i7 950
Intel DX58SO
2 GB DDR3 1300
ATI 3450
LG Flatron W1943C
Seagate SATA 500 GB
Cooler Master 400 Watt
I Ball
Your problem actually helped me figure out why my rear speakers weren't working! You mentioned that the 7.1 setup makes the sound come out of the rear speakers - this made me think that perhaps the rear speakers had instead been mapped as side speakers in the Realtek software.
To fix this, Hover over the coloured ports on the right hand side of the Realtek software until you find the one that says 'Rear Speaker Out (Speakers)'. Double click on it and change it to 'Side Speaker Out (Speakers)'.
Now, Windows and Realtek will both play out of the rear speakers correctly. Hopefully this helps someone in future...
Windows 7 Professional x64AMD Phenom II 965 BE2x2GB Apacer 800MHz DDR2 (low latency)ATI HD4850 with Twin Turbo HSF
Gigabyte MA790FX-DQ6
Creative X-Fi Fatal1ty w/ front drive bay
23" Acer X233H (1920x1080)
Samsung F1 500GB, Samsung F3 1TB
Corsair HX-620
Gigabyte Poseidon (rev 1)
Noctua HN-U12P (rev 1)
remove realktek drivers
I had a similar problem, removed realtek drivers and used Windows one and it worked :)
