HDMI audio out problem
dgud
4:22 AM
Hey!
I'm trying to hook up my pc to the tv through a hdmi cable. The image is just fine, but there is no sound coming out from the tv (the sound is always coming from the notebook)
Some things:
I updated the video drivers and the audio drivers
In the sound configuration, it says that the hdmi audio is not plugged in (but it is!)
It used to work, but I recently cleaned up my PC, and now, no deal!
Video card: ATI 5870
notebook: MSI gx660
Some time it appears some weird message on my notebook saying something about DVI and HDMI (I can't remember)
any ideas?
I plugged the audio connector on my Mobo to the Audio in on the Vid card (I asume you have done the same). Then, in BIOS, I had an audio option to redirect one of my SPDIF to HDMI.
Maybe yours has a similar option?
Windows 7 Ultimate x64 (Retail)Intel I7-860G.Skill RipJaw DDR3-1333 16GB (4x4GB)Nvidia GTS-250 1GB
Personal build
Intel I7-860
Asus Maximus III Formula
Nvidia GTS-250 1GB
SupremeFX X-Fi 7.1 HD sound system.
VisionQuest VQL-22WSHD LCD Monitor
1x Seagate ST3500418AS 500G SATA2 HDD
1x Western Digital Caviar SE16 500G SATA2 HDD
1x Western Digital Caviar SE16 750G SATA2 HDD
2x Western Digital Caviar Green 2TB SATA2 HDD, configured RAID1
OCZ EliteXtream OCZ1000EXS 1000W ATX12V 20/24 Pin Active PFC
Antec 1200
Swifteck H2O-220 Ultima XT Liquid Cooling w/ 320 Radiator
Logitech G11 Keyboard
Logitech MX518 Optical Mouse
Cable Modem
Visiontek TV Wonder 650 Theater PCI-E TV Tuner Card
Logitech 9000 Pro Web Camera
Logitech Cordless RumblePad 2 game controller
LG 18x SuperMulti SATA2 DVD Writer
NmediaPC CR98 Multi Card reader
Nmedia Pro-LCD
Corsair Dominator Memory Fan
Coolermaster R4-L2R-20ac 120mm Case Fan x2
My ATI HD4850 has built in audio, for the HDMI connection. In many cases you must manually set the HDMI as the default audio playback device in order to have audio in the HDMI signal.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Not quite sure what you meant... I plugged the HDMI port from my notebook to the HDMI port of my TV
I can't do that, it says that the HDMI audio is not plugged in and it does not allow me to set it as the default
Windows 7 Home Premium 64 bitIntel Core i7-4790G.SKILL 8GB (2 x 4GB) DDR3 F3-10666CL9D-8GBNTAMD Radeon R7 250
Intel Core i7-4790
GA-Z87X-D3H
AMD Radeon R7 250
Realtek ALC892
1920 x 1080, 1280 x 1024
WD5003AZEX
WD10EZEX
Samsung HD103SJ
Samsung 128 GB 840 PRO
SeaSonic M12II SS-500GM
Fractal Design Define R4
Zalman CNPS9900ALED
Logitech K800
Logitech M705
16 Mbps
You should be able to enable HDMI playback in Control Panel=>Sound, if it does not swap directly when the hdmi cable is plugged in.
Asus P8Z77-V LE PLUS
Asus Dual-RX480-O4G
Asus IPS 23"
Internal:
500Go Sata 6Gb/s (x2)
500Go Sata 3Gb/s (x2)
SSD 60Go Sata 6Gb/s
Thermaltake Chaser A71
Custom Water Cooling Loop
Cooler Master QuickFire XTi
Razer Imperator 2012 (4G)
IE 11.0.xxx Rtm
Hey!
sorry for taking so long (carnaval here)
so here it is the screens
(both taken while the cable is plugged in)
Asus Dual-RX480-O4G
Asus IPS 23"
Internal:
SSD 60Go Sata 6Gb/s
IE 11.0.xxx Rtm
I have this problem, but I assumed it could be that my TV is old and the firmware is not telling the comp it is capable of receiving an HDMI signal? because in my nvidia control panel my TV just comes up as "Digital Display'... like generic, when it should be giving the brand name etc., right? It's an Olevia 32"... 232-T11. IT also said that my 'Digital display' does not support HDCP. I tried rigorous detection with no luck, and for some reason Force Detection is grayed out...???
and in response to NoN ^ when it says not connected or device unplugged (even though it is plugged in), you cannot set it as default, it won't let you
Windows 7 Ultimate x64Intel Core i7-950 Bloomfield 3.06GHzCORSAIR XMS 6GB DDR3 2000MhzPNY GTX 470
Homemade
GIGABYTE X58A-UD3R
PNY GTX 470
onboard Realtek ACL889
SCEPTRE X270W-1080P
Crucial RealSSD C300 128gb SSD
Seagate Barracuda 7200.11 1TB HDD
Corsair 850TX
Antec Three Hundred
Air, 3 Scythe Ultra Kaze, Scythe fan speed controller
Rosewill RK-V1TP
Logitech M505
25mbps up and down
Hey!
Did you load the video driver from the AMD site?
The AMD HDMI driver is installed as part of the CCC driver package.
It looks like you don't have the right driver installed.
Download it from here.....AMD Graphics Drivers & Software
Intel Core i7-4790
GA-Z87X-D3H
AMD Radeon R7 250
Realtek ALC892
WD5003AZEX
WD10EZEX
Samsung HD103SJ
Zalman CNPS9900ALED
Logitech K800
Logitech M705
16 Mbps
I know this is old, but I have/had this problem. All my drivers are up to date, so I know that's not the problem. At first, I thought it had something to do with a recent driver update (which it might be, but I doubt it), but I noticed something weird today. As I was trying to fix this problem, Windows was installing some updates to my computer which temporarily made my TV screen flicker. After it was done updating, my "Not plugged in" problem went away. I say have/had this problem because it worked earlier today and I had to turn off my computer. When I turned it back on, no sound and no I have sound again. Just a thought
Windows 7 Professional x64[Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz, 330...16.0 GBAMD Radeon HD 6800 Series
Gigabyte Technology Co., Ltd/Z68A-D3H-B3
[Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz, 3301 Mhz
16.0 GB
AMD High Definition Audio Device
Phillips FTV
Hey!
I have the same problem. And the Sound panel looks the same with Digital Output + HDMI disconnected. They are both Properties > Enabled but they simply appear disconnected when I plug-in the HDMI-HDMI connector cable and I can see the image but can't hear audio on the LCD TV... :confused:
This happens also with latest Catalyst 12.8 installed + Realtek ATI HDMI Audio Device R2.70.
My MSI GX660 laptop has an AMD discrete gfx card + chipset Realtek ALC888s on the mobo.
EDIT:
SOLVED!
Have had to install 'AMD High Definition Audio Device' (version 7.12.0.7706) from Catalyst 12.4 Mobility in addition to (=with) Catalyst 12.8 video drivers. They replaced Realtek ATI HDMI Audio Device. Now audio works fine out of TV speakers automatically when I connect the HDMI cable!
Weird 6 HDMI audio device are now available, but this is ok I guess since I've read AMD 7970M supports Eyefinity with up to 6 independent and configurable screens (!).
Windows 7 Home Premium x64 SP1Intel Core i7 840QM8GB DDR3 1333MHzATI Mobility HD 7970M 2GB DDR5
MSI GX660-262it
Intel Core i7 840QM
8GB DDR3 1333MHz
Intel SSDSA2CT040G3
Hybrid ST750LX0ST750LX003
360 Internet Security
IE10
