RealTek Help!
  1. Posts : 3,187
    Are you getting any warning messages or error reports when you try it? If so, what are they? Have you tried running the installation file as Administrator?
  2. Posts : 15
       #12
    no error messages and tried running admin
    still not working
    Why is this computer trolling me T^T
  3. Posts : 834
    Windows 7 Ultimate SP1 x64
    Have you tried running the Intel Driver Update Tool:
    Intel® Driver Update Utility
    It should be able to detect the hardware, also can you post a snippet of the Device Manager, showing what items have the yellow exclamation points.
    You should try updating your chipset. The above tool should detect that automatically for you.
  4. Posts : 15
       #14
    Already used that update thingy but still nothing :C ,oh and here is the snippet
  5. Posts : 834
       #15
    Okay, then try drivers from here:
    Realtek
    This directly from the realtek website.
    Select to download the first file:
    "Vista, Windows7 Driver (32/64bits) Driver only (Executable file)"
    EDIT:
    It would also be good if you can run speccy:
    http://www.piriform.com/speccy/download/standard
    and fill out you systom information, or post a snippet here. This would let us know more about your computer hardware.
  6. Posts : 15
       #16
  7. Posts : 834
       #17
    Realtek
    Have you tried these drivers?
  8. Posts : 3,187
       #18
    Dumb question, but have you made sure the audio is enabled in the BIOS? :)
  9. Posts : 1,996
    Windows 7 Home Premium 64 bit
       #19
    Go into the BIOS and enable the onboard audio.
    Install the Realtek driver, if needed.
  10. Posts : 834
       #20
    Wait, It has to be enables in the BIOS because it is showing up on Device Manager, if it was disabled then it wouldn't show.
