RealTek Help!
Page 5 of 5 FirstFirst ... 345
  1. Posts : 477
    Windows 7 Ultimate 32 Bit, Windows Developer Preview, Linux Mint 9 Gnome 32 Bit
       #41
    I have to make another post so this goes on noticed by the thread started whose looking for help. Read the quoted statement below:
    Vertex said:
    I guess the others missed this one. Does your computer's motherboard have a setup CD?? Its the disc that says something like "motherboard setup".It should come when you bought your PC. When Windows 7 was installed, some of the drivers have to be installed again and to do that, you have to run the motherboard's setup CD because it most likely contains the driver specifically designed for the built-in sound adapter. So if you have a motherboard's setup CD, run it. But whether or not that will work with Windows 7 is a question but better than not getting a compatible driver at all.
  2. Posts : 3,187
       #42
    ryuuseigun said:
    profdlp said:
    It was still a good suggestion. If he has no luck finding the audio setting it would probably be the next logical step.
    OMG u r right i dun find audio settings
    Keep looking.
    If your BIOS screen looks like this picture, use the right arrow key to highlight "Advanced" and look around in there. (Ignore the part circled in red - that's the best picture I could find for your board and what's marked has nothing to do with what you're trying to find.)
  3. Posts : 15
       #43
    profdlp said:
    Keep looking.
    Thnk u for everything !!!
  4. Posts : 3,187
       #44
    Does that mean it works?
