Solved "Change Sound Card Settings" Question
Robert11
Power User
8:06 PM
Hello,
I do a fair amount of changing the Default and selecting the sound card that I use for various programs.
If I do a search with "sound," the Change Soundcard Settings option appears.
I click on it, and get the small screen that allows one to pick the cards for Playback, Recordings, and the Default one, etc.
No problem here.
Question: is it possible to have the screen show up continuously in the Task Bar, or generate a shortcut for the Desktop that would open it up ?
A bit of a pain to have to do a "Search" each time I want to use it.
Thanks,
Bob
Windows 7 64bit
Windows 7 64bit
Just seen your post sitting there with no response. Couldn't just leave it. Yes you can create a shortcut.
Click the start button and in the right pane click on Control Panel. There you will see "Sound" Right click on this and choose "Create Shortcut" now a shortcut will appear on you desktop!
http://www.sevenforums.com/tutorials/56892-sound-shortcuts-create.html
Microsoft Windows 7 Home Premium 64-bit 7601 ...Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz8.00 GBIntel(R) HD Graphics 4000
ASUSTeK COMPUTER INC. P8H77-M
8.00 GB
On Board
Dell 24"
500w Corsair
Cooler Master
3 Fans
Logitech MK300
Logitech WOM
75Mb
Norton 360
Firefox, Opera, IE
Thank you for this and I never even thought to ask the question!! just clicked my way through my system each time to change cards. Now that's what I call service lol
Windows 7 Ultimate x64Intel Core i7-2600K16 GB G Skill F3-10666 CL9D-4GBRLATI Radeon HD 6870
Something I threw together
Intel Core i7-2600K
Asus P8P67
ATI Radeon HD 6870
ATI Radeon HDMI / Realtek ALC892
2 x 22" standard monitors / LG32LC56v TV to watch films
1920 x1080
2 x OCZ Vertex2 111.79GB
3 x Samsung103SJ
1 x Samsung103UJ
1 x WD3200BEVT
1 x Hitachi5K320-160
Thermaltake Toughpower Cable Management 750W
Antec 300
Noctua NH-U12P SE2 and 5 120mm Case fans
Microsoft Comfort Curve Keyboard 2000
Hama M3110 / Logitech M305
I have also used Fedora, Suse, Ubuntu Linux
And all other Windows from 95 to date except ME
From OP:
Just noticed your reply to my Post.
Thank you very much; just what I was after.
Really appreciate it.
Best regards,
Bob
Windows 7 64bit
Windows 7 64bit
My pleasure!
8.00 GB
On Board
Dell 24"
500w Corsair
Cooler Master
3 Fans
Logitech MK300
Logitech WOM
75Mb
Norton 360
Firefox, Opera, IE
From OP Again: Placing Of Shortcut(s) On Bottom Bar ?
Hi again,
Not important, but just wondering.
I created the shortcut as you suggested; works just fine.
Shortcut resides on my Desktop.
I tried to place it on the bottom bar, but it won't allow doing so.
Neither to the right or the left ends of the bottom bar.
Seems like I can place other shortcuts there.
What are the "rules" that allow for some shortcuts to be placed there, and others not ?
Thanks again, and best regards,
Bob
Windows 7 64bit
Windows 7 64bit
Are you dragging and dropping or using the right click " Pin to taskbar" function?
8.00 GB
On Board
Dell 24"
500w Corsair
Cooler Master
3 Fans
Logitech MK300
Logitech WOM
75Mb
Norton 360
Firefox, Opera, IE
From OP:
Have tried just about every way.
And, the Pin to taskbar option never, ever, comes up.
Can you get it to stick to yousr taskbar ?
Bob
Windows 7 64bit
Windows 7 64bit
You are right what you say. I have investigated this further and this seems to be the definitive answer;
It seems to be definitely the case(for good reason) that only desktop
shortcuts to applications will show the pin to taskbar option when right
clicked. So if you have other stuff on your screen (Computer, recycle
bin, documents etc.) they will not show that option.
No I can't add it to my taskbar. Sorry I should have tried that before replying to you.
Seems you are stuck with just the Shortcut on the desktop!
8.00 GB
On Board
Dell 24"
500w Corsair
Cooler Master
3 Fans
Logitech MK300
Logitech WOM
75Mb
Norton 360
Firefox, Opera, IE
From OP:
Never realized that; probably should have.
Thanks for all the help.
Best regards,
Bob
Windows 7 64bit
Windows 7 64bit
