USB Noise Through Headphones
  1. Posts : 94
    Windows 7: Home Premium
    Whenever I have my headphones plugged in into the front panel and then I plug in a USB device I can hear USB working through the headphones. Almost like a little buzzing noise.
    I've had a quick look on the net and couldn't find much although someone mentioned something not been grounded properly.
    Just wondering how to fix this.
    Thanks.
  2. Posts : 21
    Windows 7 profesional
    Do you hear noise buzzing in short intervalls? I think it is normal because every soundcard have crossover.
  3. Posts : 94
    Thanks for the reply.
    Its whenever data is being transferred. If I just have the USB in its fine but as soon as I transfer a file to the USB it makes the buzzing noise.
  4. Posts : 21
    I think that is perfectly normal. Better quality soundcard has lower noise. If the sound card is integrated it will have higher noise level.
  5. Posts : 94
    Thanks, good to know.
