Need help x.x
  1. Posts : 18
    Windows 7 Ultimate x32
    Need help x.x
    Sorry that i didn't search for it much, but i tryied some thinks and the result was "a fail".
    I need help on fixing this:
    Sound control:
    *Playback tab* - speakers working
    *Recording teb* - Stereo Mix not working
    Im on rear speakers ( rear black coded ).
    I need help on configuring this - how to work.
    I can't live without music.
  2. Posts : 12,012
    Is stereo mix shown in the recording tab?
    Is it checked and shown as the "default device"?
  3. Posts : 18
    Its shown and its enabled +its a default device
  4. Posts : 12,012
    What version of Realtek do you show in Device Manager?
    What Realtek driver are you using and where did you get it?
    What is your recording application?
  5. Posts : 18
    The latest. 2.57 (3.15) 6...
    What do you mean?
    Which do you mean?
  6. Posts : 12,012
    Look at your motherboard manual. Do you have Realtek ALC 889? ALC 892? or ???
    You say stereo mix does not "work". What do mean exactly? Normally, people use it to record what they are listening to. So I asked which application you use to record?
    Where did you get that driver you listed and why did you choose that particular driver?
    Here is a pic from my Device Manager showing my Realtek Driver info. Is that location where you got your driver number from?
    What motherboard are you using?
