Windows 7: PLS Help* Headphones realtek Audio Manager
11 Mar 2011   #1
Windows 7 Ultimate x32
Hi all,
Well.The headphones works and all which is great but the Realtek Aduio Manager and Windows sound is detecting Speakers.Does anyone know how or if I can change it to Speakers?.
I would really appreciate the help,
Thank You.
Windows Sound
Realtek HD Audio Manager
11 Mar 2011   #2
Vista 64 bit and 32 bit (SP2)
Los Angeles, California + Milwaukee, Wis
If I'm understanding what you're trying to say, it sounds like your headphone port is not recognizing that the headphones have been plugged in. I would first try plugging in another set of headphones to see if the problem is the port or the headphones.
Also, did your headphones come with a CD, driver, or any other installation help? What about an instruction booklet from the manufacturer? Can you call the manufacturer's tech support to ask for help?
Also, have you checked your IDT Audio settings? Go to the Control Panel and open the IDT Audio Control Panel? Under "Speakers and Dual Headphones” go to the Playback section and then click on Settings. Check: 'Set as default.'
11 Mar 2011   #3
Windows 7 Pro x86
Mine works exactly the same. I don't believe there's anything actually wrong - that's just what happens.
There is no 'detection' going on beyond the fact that there's something connected to an analog-out jack. It has no way of knowing whether it's speakers, headphones or whatever.
You can double-click the 'Speakers' item in the list and manually assign an Icon and a Name of your choice.
Unfortunately if you plug in more than one analog-out jack e.g. speakers and headphones, you'll still only get one analog-out volume control and can only choose a single icon and name.
12 Mar 2011   #4
Lahore, Pakistan
Did you plugged your Headphones on the front USB ports of your PC Case? If yes then open the Audio Manager and click on the Folder Icon and Check the 1st option "disable front panel jack detection". Than your Headset will be detected and you will be able to use it too though it will not show any pop-up when you will plug or unplug headphones hope it helps.
 PLS Help* Headphones realtek Audio Manager problems?
Similar help and support threads for: PLS Help* Headphones realtek Audio Manager
Solved realtek audio not detecting speakers or headphones. Sound & Audio
No speaker or headphones are plugged in and Realtek HD Audio Manager Sound & Audio
Headphones vs Monitor: HDMI audio, SRS for Monitors, & Realtek ??? Sound & Audio
Realtek HD Audio Manager through headphones. Sound & Audio
Realtek HD Audio Manager and Realtek Audio Driver Sound & Audio
