Windows 7: Need help with Front Panel HD Audio
15 Mar 2011   #11
Dwarf
Windows 8.1 Pro RTM x64
I've had a search for information on the front panel audio header on this card and have come up with a complete blank. I can only surmise that it is a proprietary configuration that will only work with a specific front panel, which you might need to order from the card manufacturer.
I wish you the best of luck.
Using both front panel audio and back panel: solutions
This possibly should go in the hardware forum since it involves the motherboard as well but being a sound issue I assume here would be better. I have an Asus Xonar DG sound card on an Asus P7P55D-E LX motherboard (and AMD Radeon HD 7800 Series video card) running on Windows 7 Home Premium...
How to disable read audio panel and make the front panel primary?
Hello. I am having a not so common issue of a problematic REAR audio panel jack. The microphone pin got stuck and broken into the rear/back microphone jack and now the OS/driver thinks there is a microphone in the back panel but I just want to be able to make the microphone work on the front panel...
No front Panel audio detected but Rear Audio works on Asus P8H 61-M LX
My front USB slots work and every connector on the rear works fine yet when i plug headphones into the front audio jack and nothing is detected. My Bios are updated to the latest version, i have also tried switching to AC97 but makes no difference. Swapping between HDMI and s/pdif doesn't also...
Asus onboard audio no longer working since enabling front panel audio.
My audio rear outs used to work, but even so, i was primarily using hdmi out from my video card. I was also diagnosing BSODs at the time and sent my mobo back to asus for an rma. When it got back, I placed it in a different case and attached the font panel audio. Due to a new living...
How do I enable front panel audio ?
wud u plz advice to configure my front panel audio... I'm using realtek onboard sound... NB: MB is set for front panel audio, but when I plug my headphone in front panel, nothing happens... :( thanks...
help me with the front audio panel :(
hey guys! i'm new here, i just installed windows 7 yesterday, and i having a problem with my front audio pane both headphone and mic are not responding when i plug it in .i had Xp before, and the front panel worked without any problems, but now i can't get it working... tried the , newest driver,...
