Windows 7: Sound issue (Conexant sound driver)
13 Mar 2011   #1
Taz1
Windows 7 Home Premium 64 Bit
Ok, first of all, i'm not sure how to properly explain this, because it's confusing, but i'll try my best and if any more information is needed please let me know!
So, I bought this packard bell laptop preinstalled with windows 7 from pc world in September. And for as long as I can remember, i'm having issues with sound. Not huge issues, small issues that are really annoying.
What basically happens is, when i play music or any other sound, it plays fine, clearly, through my speakers and headphones (tested both), but every 30 seconds or so, it makes a buzzing noise that lasts around 2-3 seconds (sometimes longer, will be explained), and during those 2-3 seconds, my computer basically freezes. I can't move my mouse until the buzzing stops. This only happens when sound is played. I've had it tested and the sound card proved to be fine, so i'm not sure what the issue could be.
Occasionally, the buzzing would last forever, until I have to hold the power button down on my laptop, because I can't move the mouse/do anything, this happens rarely though, its more of a 2-3 second thing.
Some information about my speakers/drivers:
It's a packard bell easynote tx86, installed with:
Conexant High Definition Audio, and Intel (R) Display Drivers (According to device manager)
It has Dolby Home Theater featured on the speakers
On the control panel, according to the playback audio devices, it has: S/PDIF interface, a long with just "Speakers", both powered by the Conexant High Defintion Audio drivers. No clue what the S/PDIF interface's role is.
If any more information on drivers/speakers are needed i'll do my best to provide.
I've also done a reformat, to no avail, and have tried uninstalling my sound drivers, and installing the ones from packard bell's official website, also to no avail, so am really cringing for help.
Thanks alot in advance, and if any more information is needed, please ask.
14 Mar 2011   #2
Taz1
Really need help
04 Apr 2011   #3
paaants101
Hi Taz1
I've got the same laptop and I'm having the same problem although not so severe - the buzzes last only half a second on mine. I haven't found a solution yet I'm afraid. I've tried installing all the drivers I could find, no luck. Tried reseting the computer, no help. Now I've just got my computer back after it had it's CPU and hard disk replaced and the problem has just occurred again.
The buzzing noise sounds to me like it's getting caught in short loops. It's playing the same tiny fraction of the music over and over thirty or so times before continuing which makes it sound like a buzzing. I'm not sure if that brings us any closert to a solution but there you go.
I'll try The Tech Guys again and see where I get. Although all I'm getting is sick of their call holding music.
Mark
04 Apr 2011   #4
Taz1
Quote   Quote: Originally Posted by paaants101 View Post
Hi Taz1
Mark
Thanks for the reply, if you do find anything from Tech Guys, please do let me know
I have also reformated my PC, new hard disk installed, etc
05 Apr 2011   #5
pooch
Quote   Quote: Originally Posted by Taz1 View Post
This is just another connection and nothing to do with the problem
Hello Taz right click on the speaker device and select Properties , Enhancements place a tick in disable all enhancements select DTS effects and check that nothing is enabled now try it again and see if there is any change.
These settings have been known to cause problems if it still does not improve I would suggest taking it back and getting it fixed under warranty
conexant sound driver no stereo mix?
i dont find the stereo mix in my laptop sound option there
Hardware & Devices
Conexant Sound Driver does not install
hazeleyes202
can't find Conexant sound card stereo mixer driver
I have a new ACER Aspire 5250-0810 and i have not been able to find a stereo mixer. This is not a huge deal. But i would like to share music i am listening to while video chatting w/out having to use mic. The sound is distorted and i don't want chat partner to hear me. Is there no Stereo Mixer...
Drivers
HP Pavilion DV6324 No Sound Conexant
Hello, Ran a Windows 7 upgrade 32bit on the dv6324, everything works alright except for the sound. However, the weird thing is -- it appears as if the sound card drivers are installed and working properly. In fact, the volume bar is even green, and you can slide it around as if it was properly...
Conexant Ac-97 Sound Problem
Hello there. Well, after reading several threads, tried different drivers, I cannot get my sound card to work with Wndws 7 64Bit, so, I use this thread as my last resort. I have a Hp Pavilion Zd8000, conexant AC-97 device, as I said bfre, Windows 7 64Bit, I know that there has been several threads...
Conexant sound card not working
I have recently upgraded my HP Pavilion zd8180ea notebook from XP to Windows 7 x64 Everything works except for my sound card, there is no sound at all :( It's a Conexant CX20468-31 AC97 and I cant seem to find any drivers for it on windows 7 that works. Somebody know how to get it to...
Drivers
