Windows 7: I Need help with 7 sounds
19 Mar 2011   #1
Jack8530
Windows 7 Home Premium
Hey,
My Click noise is deactivated and i cant find how to activate it again anyone help?
Thanks Jack,
19 Mar 2011   #2
Brink
64-bit Windows 10 Pro
Hello Jack,
This may be able to help with that.
Clicking Sound while Browsing Internet and Windows Explorer - Turn Off
19 Mar 2011   #3
Jack8530
Thanks Brink, Your the best at fixing my problems
19 Mar 2011   #4
Brink
You're most welcome Jack.
Sounds almost sci fi
Found this in a news letter I get - Summary
News
about sounds
Hi i was wondering is it possible to add new sound to, for example, "Send to Trash", or, "Move File", like Macintosh? You know what I mean? Thanks
No Windows Sounds, but regular sounds play fine
Ok so I have a simple, but annoying problem. I have no Windows Sound Events like the login sound, the logout sound, and when the battery is low. Every other sound like playing music and running YouTube videos work fine. Even when I turn on my laptop I hear the whole computer startup sound, but I...
More sounds
Where can I get more new sound themes or can I?
Sounds
I have seem to have some sounds missing ie in Internet Backgammon and my avast AV. Any suggestions?
Bad sounds
Hi.I have a big problem.When I'm listening music or playing games I can hear very bad,terrible sounds.I seen that bass level is very high.But I can't move slide. It's screen shot. http://www.ipix.lt/thumbs/63807185.png
