Sound not coming out from the TV Speakers using HMDI
zayoun
8:16 AM
Dear All,
i really need your help.
i'm trying since last week to get my new Samsung HD TV to work on my Desktop.
after a lot of google researches, i've figured out how to get the HDMI output Option from BIOS setting,
i successfully set it up as default and everything seems fine, BUT the sound is not coming out.
My VGA is DVI AUDIO Enabled.
the connection is DVI to HDMI adapter, then HDMI to HDMI Cable to the TV.
i even treid to connect audio cables from the sound card to the DVI/HDMI 2 port in the TV, but again no luck :(.
any ideas guys??
Windows 7 7232 x64 bitintel i7 920 @ 2.678 GB DDR3ZOTAC GEFORCE 260 Square 896 MB DDR3
intel i7 920 @ 2.67
Asus P6T
8 GB DDR3
BUILT IN REALTEK HD AUDIO
SAMSUNG 32" TV HD READY
1 TB Western Digital 32 MB Cache
600 WATT RAPTOX
iCute Full Tower Case
normal air cooling with 3 fans support.
sound issue
Dear All,
any ideas guys??
First welcome to SF and thanks for filling n your system specs
Im going to start with the basics. you updated the audio driver to win 7 right?
Ken
HP Pavillion dv-7 1005 Tx
Win 8 Release candidate 8400
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
Had the same issue with my LG lcd tv, turned out it was a setting in the audio tree of the tv menu itself . . .
Hope this helps
Scott
Windows 7 Rc Build 7264 x86, UbuntuIntel Q8200 Quad Core2 GbnVidia 8400GS
Asus P5QL
2 Gb
nVidia 8400GS
Stock Realtek HD Audio
Hp 2207h and LG 42in LCD
1680 x 1050, 1360 x 768
250 Gb seagate internal, (2) Western Digital 1 Tb external
Corsair 550W
Thermaltake DH 102
Unmodified
Microsoft Wireless
Microsoft Wireless
Time Warner - 15mb\s
4 ATI Digital Cable Tuners, 1 XBox 360, Life|Ware home automation,Yamaha RX-V765, Harmony 1000 Remote
Once I had this problem and finaly I it cleared out that the HDMI cabel was bad.
I went to a shop and told my problem to an expert and he said that there are some crazy cable on the market what seems to be work but not really the way we want it :)
After i bought a new cable - the most expensive one what i found - it worked well.
Windows 7 RTM x64AMD X2 5000+4GBNvidia 9400GT
home made
Windows 7 RTM x64
AMD X2 5000+
Asrock
4GB
Nvidia 9400GT
onboard 6Ch
Medion 22" + HannSpree 22"
1680X1050 + 1920X1080
Intel SSD 80GB
WD 1.5 TB
WD 1 TB
Samsung 1TB X 3
noname
noname
Zalman
DeLUX multimedia keyboard
Microsoft
25MB/s
zigzag3143,
thanks a lot, am proud of my system specs :) , and to answer your question, Yes i updated to the latest driver 2.77 from realtek.com
by the way, am a very advanced PC User. which am proud of again:) . but this thing really killed me, i tried every single possible thing.
Webadict,
thanks for the info, but i already checked it, there is only one thing weird, ti have something called "Sound Select", and the option selected is "Main". which i cannot even play with it as it is Grey Colored.
intel i7 920 @ 2.67
Asus P6T
8 GB DDR3
600 WATT RAPTOX
hi Robertoszwald,
your idea is the first one that i read regarding the cable,
i have a Touchmate HDMI cable, which is cheap. but original...
but am totally with you. what is your cable Brand so i can search for one...
i reached a point that windows 7 is the cause as a lot of ppl said its working fine on vista.
as i said up as well, i tried to connect audio cables from the sound card to the DVi port in the TV, but no luck again.
intel i7 920 @ 2.67
Asus P6T
8 GB DDR3
600 WATT RAPTOX
hi Robertoszwald,
Sorry I can not remember the brand and i am not at home now to check it. If you still need it an next wednesday i can tell you.
Isn't it possible that your TV can not handel the hdmi sound? i don't know much about it, but may be you should try to give it only a single stereo sign if it is possible. If i'm right your TV has only stereo speakers, may be it has to downsample the audio to stereo, and may be it can not do it. Then you have to do it on the PC within the media player program. I've got no more ideas. And sorry if I said silly things.
home made
Windows 7 RTM x64
AMD X2 5000+
Asrock
4GB
Nvidia 9400GT
onboard 6Ch
Intel SSD 80GB
WD 1.5 TB
WD 1 TB
Samsung 1TB X 3
noname
noname
Zalman
Microsoft
25MB/s
Stupid question time. Did you remember to connect the SPDIF cable that should have come with your video card, from the cards SPDIF header to the SPDIF header on the motherboard?
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
stormy 13,
thank you for the Stupid question time, i checked it out, it was connected to the motherboard in the wrong order. just converted them to the correct position. and everything went fine.. :)
thanks a lot again guys, if anyone needs something just buzz me.
intel i7 920 @ 2.67
Asus P6T
8 GB DDR3
600 WATT RAPTOX
stormy 13,
:what::roflmao:
home made
Windows 7 RTM x64
AMD X2 5000+
Asrock
4GB
Nvidia 9400GT
onboard 6Ch
Intel SSD 80GB
WD 1.5 TB
WD 1 TB
Samsung 1TB X 3
noname
noname
Zalman
Microsoft
25MB/s
well Robertoszwald,
things happen sometimes... i assemble a pc every week almost. :D. but this it seems i was totally sleeping when fixing it :p...
anyways mistakes happen sometimes :o
intel i7 920 @ 2.67
Asus P6T
8 GB DDR3
600 WATT RAPTOX
It would be very boring if everything goes well for 1st time! :)
home made
Windows 7 RTM x64
AMD X2 5000+
Asrock
4GB
Nvidia 9400GT
onboard 6Ch
Intel SSD 80GB
WD 1.5 TB
WD 1 TB
Samsung 1TB X 3
noname
noname
Zalman
Microsoft
25MB/s
At least it was a nudge in the right direction. :D
Been there, done that myself. We won't discuss swapping hard drives around between computers and them not working (something to do with jumpers :doh: ).
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
robertoszwald,
i have a belief in something about assembling PC's.
each time i assemble a pc, i MUST hurt one of my fingers :D.
stormy13,
i have a lot of headaches from jumpers in the past, but the last problem was like 3 years old now. SATA solved all these issues.;)
intel i7 920 @ 2.67
Asus P6T
8 GB DDR3
600 WATT RAPTOX
