Windows 7: Can't display Sound "Volume" icon?
23 Mar 2011   #1
I can't see the volume adjust button on the bottom of the screen (laptop). I check the system on/off for Time, volume, network, etc... and the volume one is dim (can't change from off to on). What I need to do to turn the volume on so I can adjust the sound.
Thanks,
23 Mar 2011   #2
Quote   Quote: Originally Posted by subhadip View Post
Make sure whether you have sound drivers installed or not.
The sound come out the speaker without any problem and I can adjust with fn-f11 or fn-f12. The problem is the volume icon can't display on the task bar.
23 Mar 2011   #3
Might try the following on this link.
System Icons - Enable or Disable
23 Mar 2011   #4
windows 7 ultimate 64 bit
go to control panel>all control panel items>notification area icons>system icons & restore default icon behaviors.
23 Mar 2011   #5
I already check on this but the volume icon on the notification area is dim (can't turn). Even I choose the restore default icon behaviors but the Volume icon still can't turn on.
14 Oct 2011   #6
Same problem, applied Windows 7 "quickpatch" from Microsoft, effect: disaster all icons vanished, all notification area icon checkboxes now BLACK! Tried Restore to last remembered working icons. Success.
18 Feb 2013   #7
Windows 7 Home Premium
I was having that same problem and I logged off and then back on and it was there again. Try that.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
